Results 1 to 10 of 10
Thread: Electric Windows
    luvmycommodore's Avatar
    luvmycommodore is offline Mum's Taxi *sigh*
    '02 VXII Acclaim Wagon
    Jul 2005
    Clarence Valley, NSW
    Question Electric Windows
    Does anyone know much about them? My drivers side window button sticks and won't open half the time. If you press it *just* right it works.
    Now i *think* the kids may have spilt something over the buttons - my question is... are the contacts for the buttons that may just need cleaning?... is it something i can do myself? and if so, what's the easiest way to get to it.
    Cheers guys
    Manda
    walking the tightrope between good and evil
    mal_iboo Guest
    Default window switch
    not sure if yours is the same as mine, but
    i pulled the button mechanism apart. inside are little plastic rods..approx 15mm
    one of mine was worn down for some reason. i replaced it with a piece of plastic that i shaped to the original shape of the original. i used a toothbrush handle (strange) for this. it is still going strong after 2 years.
    hope this helps.
    i need help with my driver side window doesn't completely close sometimes......any amswers?
    myberlina's Avatar
    myberlina is offline BAD COP! NO DOUGHNUT!!!
    2006 VE Calais
    Aug 2005
    Melbourne, VICTORIA
    My back passenger window would go down but not up when using the rear window button.
    Upon taking the bastard switch apart I found that someone has been a little trigger happy with my berlina and shorted the contacts internally. The contacts were completely BLACK.
    Cleaned the whole set of contacts with a rag and now she is all good. Although the back windows are now disabled most times to prevent a re-occurance. Yes... my friends are idiots even more so when drunk.
    I hate being taxi. The answer to your question I reckon will be cleaning the contacts inside the switch. If that doesnt work then you will probably have to get a new one although unlikely I think.
    Jul 2005
    Thanks, so how do i get the surrounds off the window controls so i can have a look at it? And if it needs a professional is it a costly fix?
    Manda
    Mr Invisible 55 Guest
    Post Window switches
    Hey guys does any one else have a problem with the lights on the rear back window switches not working?
    if so how do u fix them ?
    is it expensive?
    and can i do it my self?
    thanx
    RYAN!!
    B J
    B J is offline
    VTS
    Sep 2004
    Townsville Queensland
    Quote Originally Posted by Mr Invisible 55
    is it expensive?
    thanx
    RYAN!!
    Yes, funnily enough my rear passenger side has light in the window switch has blown twice over the past 4yrs I have owned the car tho. Because it is so long between blowing I just replace the bulb. It takes a really small LED that sits in a rubber stand that gets pushed onto two pins between the rockers inside the switch. If you take the switch apart, you will know what I mean. Just grab the LED that is in the black rubber casing and pull it straight off. You will see how the LED's terminals are wound around. I got the LED's from and electrical shop - Jaycar eg. for $2 or something. I would take the old LED with you so they can get the right one. The LED is clear as it has a little green cover. Hope this helps.
    VTS
    myberlina's Avatar
    2006 VE Calais
    Aug 2005
    Melbourne, VICTORIA
    LED???? My ones are normal everyday globes!!!
    Maybe things are different in my VX? Was going to change them but couldn't be stuffed. As long as the button works up and down I am happy.
    myberlina's Avatar
    2006 VE Calais
    Aug 2005
    Melbourne, VICTORIA
    Quote Originally Posted by luvmycommodore
    I prised the window switch panel out with a screw driver VERY lightly. After that, you can disconnect the terminal plug at the back and the panel is all yours.
    To open it up, I am unsure. I haven't done it to the front window switches before... only the back ones.
    Should be some clips around the outside of it just like the ones on the back. Once you get the back-board of the switch panel out you should see whats inside.
    If you do open it yourself... I would suggest a clean kitchen table or similar surface. Parts will fall out when you initially open it and these parts can be very small.
    Hope this helps.
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    Yes I had the same problem with my back switches, dirty contacts. Cleaned and working beautifully. My drivers side stopeed working altogether. I pulled the main control deck of the centre console. Pulled her apart, the drivers brass contacts were black as. Cleaned every contact up, all windows working a treat.
    Yours Kindly,
    Jim
    Jul 2005
    Jim that's what i need to do i think... how'd you get the surrounds off the centre consol? I don't want to break anything. TIA
    Manda
  1. Electric Windows
    By moganman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2009, 12:18 PM
  2. Electric windows
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2007, 03:11 AM
  3. VQ electric windows into VR
    By -UNKNOWN- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2006, 01:02 PM
  4. Electric Windows
    By TigerVX in forum General
    Last Post: 05-06-2006, 11:53 PM
  5. electric windows VL
    By sparrow25 in forum Electrical Wiring / Questions
    Last Post: 14-04-2005, 08:47 PM
