Is a VT dash cluster compatable with a VX? I got a VT dash cluster, but when I put it in my VX the tachometer does not work? The diagnostic test, (one of the hidden trip computer functions) shows all guages to be working, but when the engine is running the tachmeter doesn't work, just stays on zero.
Any help will be appreciated.
3 is always greater than 2, even for extremely large values of 2.
The cluster probably needs to be programmed to suit your vehicle, the tacho needs to be set to the correct type & speedo pulses etc all need to be programmed. This needs to be done with a Tech 2 at a dealer.
Rob
