Page 7 of 8 FirstFirst ... 345678 LastLast
Results 151 to 175 of 176
Like Tree3Likes
Thread: VT - VX Faults
  1. #151
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    thay cost a bomb
    Quote Originally Posted by dylanstone View Post
    cheers iv already read that before
    thanks for the help i guess ill just take it into a garage and see
    $$$$ which is a bummer
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  2. #152
    cruizin is offline CRUIZIN
    VT HSV CLUBSPORT
    Mar 2010
    MANDUAH
    Default Vt Cubsport Problems anyone have any ideas Please --- Jacqui
    Vt Cubpsport Problems HELP
    hey guys thought id come in here and pic some brains as i know you guys in here have more than most of the mechanics ive been sent to lately.
    my problem is i bought Vt HSV clubsport 99 model a year ago paid 14,000 yeah got ripped i know and big mistake bought it from a car yard MOTORSPORT in Kenwick SO DONT GO THERE..
    anyways
    MY PROBLEMS
    looked over the car when i went to buy it and noticed a slight film in water bottle, being new to the gen 3 asked the salesman to explain. his answer with the new gen 3 they run them with conditioning pills in the water to help the radiators and oil components in radiator. seemed feazable...
    NOPE WRONG
    air conditioner wasnt working..
    their answer Just the switch not ligting up
    NOPE WRONG
    and the list goes on yeah yeah i know i shouldnt have bought it but hey id always wanted one and seeing how id had a car accident and got a ltitle pay out i decided to buy my clubby, and Lo and Behold i Trusted the Salesman... WRONG again.
    Anyways to pic your brains. when i go to open the car with the key, only the left hand front indicator and rear left light work. YET if i open the boot with the key all lights flash. NO ALARM THOUGH.
    hasnt had one since i bought it.
    i was told BCM bought that No diff
    since ive had this car ive replaced in 12 months. the diff cvs starter motor alternator front seal radiator BCM pulleys belts condensor x2 compressor exhaust map sensor oil sensor oxygen sensors relays and fuses
    still dont have the alarm or light things worked out
    after asking holden they told me that i couldnt put an aftermarket one in as my clubby already had 2 systems come stock with the car..
    Any help you guys with this ... today i picked the car up from AWN s warranty people and have 2 cracked side skirts GREAT new ones sell for $620 each sob sob any help would be greatly appreciated
  3. #153
    LUXL67's Avatar
    LUXL67 is offline VIPCALAIS
    vx calais
    May 2010
    Tasmania
    Hi guys, im new at this, i got a 2000 model vx calais s2 l67, i put a dash out of a vu that had been crashed, when i put the dash into my car the air bag light came on but my air bags havent gone off, so i put my calais dash back in but the air bag light is still on. Need help?????? I have diconnected the battery for ten mins but still nothing. Any help would be good thanks
  4. #154
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    Quote Originally Posted by LUXL67 View Post
    yeah it happens when stuff gets unplugged, mine done it when i get my stereo installed because they unplugged my electric seat or something, anyone with an edit programe can reset it for you
    Going where no late model stato/caprice has gone before.... GAME ON!!
  5. #155
    Leo.Bullterrier Guest
    I took a look in the faults section for our VX Accliam and can't see this, how hard is it to remove the front left side inner door trim like are they screwed on our just cliped. Ours had a slight rattle once in a while when we purchaed it 16 months ago and now it has the rattle all the time. I'd say something has come loss inside but I need to know if we can insoect ourselves or is special tool required. I'm the main driver and hubby would rest his leg against the inner trim which stops the noise but now that he works 14 days on at a time theres no one to hold pressure against it and I want it fixed.
  6. #156
    5.0LTR VT BERLINA, WH STATESMAN V6 S/C
    Apr 2011
    Mackay QLD
    walesy's Avatar
    Jun 2005
    Perth SOR
    Quote Originally Posted by Leo.Bullterrier View Post
    hey leo, to take off the inner door trim all you need is a phillips head screw-driver, and a very small flat head screw driver...
    use the small flat head screw driver to pry out the little cap you would be able to see on the inner door handle (its a little circle cap, there is a screw behind it),
    the inner door handle can then be taken off and from memory there is another screw behind that.
    then use the same screw driver to pry the small cap from the door lock (it should be a little red kidney shape cap when the door lock is popped up).
    the door lock can then be lifted of and there is another screw behind that.
    then there is about 8 or so screws around the outside of the door trim just undo those and the door trim should come free, you will have to pull the bottom out a bit then lift the door trim up, you should be able to see how it is held on...
    you will also have to unplug the light in the door.
    putting the door trim back on can be a little tricky getting it to sit in properly, and same with putting the inner door handle back on getting the metal rod back on but its a patience thing
    hope that helps
  8. #158
    99 Commodore VTII 3.8L Exec Wagon
    Dec 2010
    Coomera
    I new to this commodore too, first time i have bought a commodore VTII wagon it was in pretty bad shape . got it cheap.Under $3000 But! it rides worst than my last car. Anyway has a lot of faults , but i haven't got a lot money to fix them. So feels like driving an overpowered horse drawn carriage.
    I'm stuck on replacing my wheel bearings , need a tool to remove them. anyone know how or can give me a link to a thread about this?
    Thank you
  9. #159
    goose2's Avatar
    goose2 is offline 40. the new 20
    VT BerlinaWagon/VZ exec wagon
    Sep 2004
    Ballarat, VIC.
    by using a trusty bent flat blade screw driver after removing the pin on the left side of your trapdoor there is a latchtoward the rear of the bin on the rhs press this in and the whole door assy comes out... if you have a series 1 type(black trigger type) i suggest you replace it with a series 2 type (white trigger type) less problems you dont have to remove any screws to replace the door 2nd hand these sould be $10-$15 or less
    If i wanted to break ya balls i woulda kicked ya girlfriends handbag
  10. #160
    goose2's Avatar
    Sep 2004
    Ballarat, VIC.
    Quote Originally Posted by commaggi View Post
    Please can anyone help?
    My VX Eurovox CD player shows erroe code E 3 and usually ejects CD.
    Sometimes it shows track 01 and looks as though its playing ,but no sound comes out.I have tried a search with no luck.
    I was pleased to see your fix for the little latch on the door under stereo, as I need that repair too.
    Also the volume up and down buttons on the steering wheel,are they relplaceable,or does it require replacing the whole R h side unit?
    Thanks for your help in advance.
    the volume switches are a pair and require the air bag to be removed to change them over(no biggie)disconnect your battery before removing airbag(she can go bang) undo the two torque screws either side unplug from clockspring and refit in reverse as for your stereo try a s/h one
  11. #161
    goose2's Avatar
    Sep 2004
    Ballarat, VIC.
    have you replaced your coilpac and dfi modual? they dont like to get hot moreso when there old
  12. #162
    goose2's Avatar
    Sep 2004
    Ballarat, VIC.
    Quote Originally Posted by LOWS2 View Post
    Hi all,
    Ive got a 2001 VX Berlina, Series 1, gen 3, 97,000klms and it has a problem with the blinkers. They will work fine for a short period of time but after a few uses, both sides will come on at once (like the hazards are on) even though i have only chosen left or right.
    i have replaced the flasher unit with no change, could it be the stalk or relay?
    Anyone had the same problem?
    Cheers,
    Mick
    Had the same prob with my VT2 replaced the stalk all better
  13. #163
    goose2's Avatar
    Sep 2004
    Ballarat, VIC.
    anotherone is the gearshift knob(auto)poping up.. It brakes at the roll pin in the selector .to fix this you must remove the center consol and gear indercator cover, remove roll pin grease new plunger and spring (first remove knob grip by removing screw on front of shifter)the replace grip with new button and push roll pin back in took me about 45mins
  14. #164
    VT Berlina S1
    Dec 2009
    Adelade SA
    Creaking coming from both front doors during general driving, how to fix??? im sure its the electric windoes as they rattle when down. rear passenger door handle is broken. hand break alarm keeps sounding.
  15. #165
    VT SS 5 Litre
    Jul 2010
    Whittlesea
    Hi,
    I've a got an ABS light displayed on my dashboard on my VT wagon, but brakes still work fine. does anyone know much about the ABS modules on these, and how i can test it or is it likely to be another fault?
    thanks
  16. #166
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    Hi there all,
    I have a series 1 VX Wagon with the Gen 3 engine. The problem I have is the dash lights are all staying on, as soon as I start the car all the instrument lights come on.
    If anyone has any ideas this will be greatly appreciated.
    Simon
    Lets work as a TEAM and do it MY WAY!!
  17. #167
    vx
    May 2011
    sydney
    Cool lights n beeping randomly
    hi guys
    had a few little probs with my vx over the past two months, got the ingetors all fixed up thanks to those who helped
    now we had to jump start my car i left the lights on while parking, (lol yeah i know) now when i am driving the lightning bolt light, abs light, trac off light, and air bag light come on and give 3 lots of 3 beeps, then it goes away, then the same lights plus the oil light come on with 2 lots of 3 beeps and 1 lot of 5 beeps
    can anyone help me as to somehow fix this problem, i know theres nothing wrong with the things showing up as it does this randomly while iam driving
    sorry to b a pain guys but love my tiger car any help is appreciated
    thanks
    jenn
  18. #168
    1998 vt sedan
    Jun 2011
    pottsville
    Default the air bag light ?????????
    Hi this is my first post today . I transfered the rego from QLD to nsw and when we got the roadworthy done thay told me we had to get the air bag light reset in the dash. so straght over to south tweed auto once there it was a easy to reset for them with the wright skills . but then on the way home bang the light came back on ?? HELP
  19. #169
    vk executive
    Apr 2005
    hi guys ,hope someone can help with this annoying prob 2002 VX Acclaim high beam warning light does not work i have taken out the globe and changed it 4 times and no joy Any ideas?TIA
  20. #170
    Holden VX II SS 6 Speed ;)
    Aug 2011
    Perth/WA
    Default Reply
    Quote Originally Posted by VXWAGMAN View Post
    Haha.. I wanna use it though. You can replace it with replacement bits worth 10 bucks. Trouble is you gotta rip off half the console to get to it.
    Tell me about it, my old VT Did that, had to rip the whole fasia out for that stupid little white clip... but it did settle most of my frustrations after
  21. #171
    Commodore VT 3.8 (Omega CD) 2000
    Aug 2011
    Brazil
    Hello everyone, I would like to congratulate the forum, it is very complete and organized.
    I think it has a differential problem in my VT, it seems that he has a backlash when the reverse gear engages. the other problem is the gearbox shift up at low speeds are a bit abrupt.(automatic transmission)
    Thanks a lot..
    Alessandro.
  22. #172
    vn calais 5.0
    Jun 2011
    victoria
    Trying to solve the heating problem on the sister inlaws vt wagon v6. It has factory gas and auto.. The temp guage reads hot and comes up with hot on the dash but the motor is still cool.. Is there a code check thingy like in the Vn-Vp? They have had the wagon at the mechanis and they cant find whats wrong with it.. They had the computer sent off to get checked and its good.. Any ideas?? Thanks heaps for the help..
  23. #173
    waynenos is offline waynenos
    vx Equip 2000
    Feb 2012
    Hobart,Tasmania
    I have a vx equip.The prob i am having is when we get a very hot day, whilst driving, the engine just stalls.We have had the Crank Shaft Censor replaced, but as soon as we got some very hot weather it started doing it again,after a while it will start again, but if it is still hot it will stall again.. Would anyone have an idea as to what is coursing this.
  24. #174
    2001 VX Acclaim
    Mar 2012
    tytower is offline Banned
    VX
    Apr 2012
    Mackay
    Quote Originally Posted by VS Omega View Post
    These links are great to help identify problems you're having with your car or if you're purchasing one of these cars they're some things to look out for.
    VT: Click here for faults
    VX: Click here for faults
    Note: I'm not the author, just bringing his work to everyones attention!
    For me the VX URL went to the VT page ?
  1. VN - VP Faults
    By VS Omega in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2012, 08:40 PM
  2. VE faults?
    By GenOktOniA in forum VE Holden Commodore (2006 - ?)
    Last Post: 14-05-2008, 10:45 PM
  3. VR - VS Faults
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2008, 11:04 PM
  4. what do these faults mean??
    By harro_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2007, 10:47 PM
  5. Other Faults with VP
    By ivaninoz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2007, 10:10 PM
