These links are great to help identify problems you're having with your car or if you're purchasing one of these cars they're some things to look out for.
VT: Click here for faults
VX: Click here for faults
Note: I'm not the author, just bringing his work to everyones attention!
great find, very helpful.
That the automobile has practically reached the limit of its development is suggested by the fact that during the past year no improvements of a radical nature have been introduced.
Scientific American, June 2, 1909.
Drinking and driving: there are stupider things, but it's a very short list.
yes i agree some very good information
also great info could come in handy
Thanks for the info. I have a few of those little niggling items on the list![]()
Ciao ...
Feel The Thunder...
I got a few to add to the VX list:
The little compartment in the dash. The close lock mechanisim breaks and the little door won't stay closed.
Also a lot of VX models have has issues with the fuel gague units. I've had my whole unit replaced luckily under warranty.
-= WAGEN3 =-
My lil compartment broke to, fix it wit super glue be workin fine how for months
Haha.. I wanna use it though. You can replace it with replacement bits worth 10 bucks. Trouble is you gotta rip off half the console to get to it.
-= WAGEN3 =-
I replaced mine a few months back, little latch from Holden $12Originally Posted by VXWAGMAN
2 min job didnt need to take the dash appart at all. The compartment
pulls out, flick the latch out, put the new one in...push the compartment
in, and job done
Was thinking about putting up some pics and walk through when I did it
but never got around to it.....and dont know if someone else has done it already
Vxwagman it still works the clip that holds it shut broke so i pulled it apart and fixed it with superglue
or when you open the boot, the rear boot garnish empties a load of water in to the boot, or onto your head.
I get that alot. Usually on my head :-S
I'm amazed they didn't pick on the tyre scrubbing issues!
Ones I have found
1. Fuel gaudge up the creek is not accurate
2. Boot dumps water on your head
3. A lot of parts not zink coated or even painted and start to rust at an early stage
4. Boot stop rubbers hold water under neath and rust starts
5. Dirt and water sit in the wells in the engine bay
6. Plastic bumper on VX Berlinas continue to pop out dont line up grrrrr
7. Painted sufaces (excepting outside body) are a very thinly coated and will not be long before corrosion takes affect
just a few that I have found
Ok after a few PM's asking me how this is done, thought I might place a few pics and steps up of how to replace
this latch. Sorry for the limited pics, was running out of battery power, but hopefully you get the general idea.
Pic1.
Open up the dash bin, and in the left hand corner you will see a pin. Remove this pin, it simply just slides
out of place.
Pic2.
Once the pin has been removed, apply pressure in the direction the arrow is pointing, and at the same time
pull towards your body. Dont apply too much pressure tho as the compartment will slide out easy enough to
gain access to the Latch.
Pic3.
Once the compartment is out, this is where the latch sits, push the latch out of position and replace with
a new latch (Can buy them at Holden $12).
Pic4.
Latch been removed from the dash bin assembly.
Now just reverse the procedure, push the compartment back in to place until you hear it clicking back in to
place and push the pin back in to location, and you're done.
There wasnt a section in there under electrical about dashes
By dashes im talkin bout the instrument cluster ive been havin problems with it for a while usually it goes within seconds but has been stayin on longer lately and the holden dealership have no idea what it is.
In relation to the boot and emptying water.
Im assuming you all have spoilers??
If this is correct change the gaskets for the spoiler thats what i had to do to stop mine from leaking.
By memory they were $17 from the dealership.
very helpfull site
Very helpfull info thanks guys
Does any VT owners have these problems:
1) the covers that hide the screws in the interior fall out of random places
2) the glovebox breaks on the boot release button side.
[QUOTE=WinterVX;399988]
Pic2.
QUOTE]
Just for the benefit of others - My unit was secured by 2 screws (one on either side) - which where hidden behind the gear selector shroud and scured to the front of the bin unit.
Not sure removing the pin did anything - but until I accessed the 2 screws (meant loosening the centre consol unit) - the bin would noy have been able to have been removed.
My car is a VX Spav 2001 model.
Thanks anyway for the original posts - very helpful
WINTER VX - YOU ARE A JET!![]()
Just got the thingo out
Thanks a 1,000,000
Cav
