Results 1 to 6 of 6
Thread: O2 Sensors
    Mar 2004
    Exclamation O2 Sensors
    Has anyone heard of putting heat bandage on extractors to take heat away from from sensors. The sensors have been tested and are good, but engine light comes on and off while driving.The mechanic at Holdens told me, "it could be the silastic they used burning off" or "the sensors are getting hot"
    jack.mc's Avatar
    jack.mc is offline Nothing witty to say :(
    VN Vacationer
    May 2005
    Sydney, NSW
    I have the same problem on my VN, have been trying to find a solution for 6 months. Could it be the same? Please, let it be the same? I just want to know how to fix it!!! BAAAHHHHH
    2000 VX Commodore
    Jun 2005
    Quote Originally Posted by yeah,yeah
    I haven't heard of it being used for that but might work.
    I assume you have checked the fault codes to make sure that is the reason for the engine light?
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    the problem isnt the heat, its the lack of it. When extractors are fitted sometimes the o2 sensors dont get hot enough, the heat bandage may help. its not so common on v6's try a new sensor first.
    If silastic or some other silicone sealer has been used it may have destroyed the sensor, it is not reversible damage.
    Cheers Rob
    Mar 2004
    2000 VX Commodore
    Jun 2005
    It was checked by holdens and sensors came back as working.
    Exactly. How do you know it is the O2 sensors setting off the warning light? Maybe there is something else causing the fault...
  1. O2 Sensors how many
    By miedwards in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-07-2006, 02:54 AM
  2. what do i do with sensors with air pod in
    By crainy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2005, 08:58 PM
  3. v6 and v8 o2 sensors
    By aero19 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-08-2005, 05:37 PM
  4. sensors
    By CAFA_TF in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2005, 09:20 AM
  5. O2 sensors...
    By MY_95_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2005, 04:58 PM
