+ Reply to Thread
Results 1 to 12 of 12
Thread: Removing Air Box
    VT Wagon
    Jul 2005
    Default Removing Air Box
    Hey all,
    Was wondering on how the hell you remove the lower air box from a VT v6 Commodore. Tried on the weekend and i couldn't get the two weird looking screws to move.
    Any help would be great.
    vt in progress
    Sep 2005
    Have you tried a ratchet with a long extension. Thats how I get mine out.
    VT Wagon
    Jul 2005
    inside the air box or inside the wheel arch? cause there seems to be a nut inside the wheel arch. And in the air box it has a weird type of head to it.
    xu1au Guest
    i havent had a vt for long why u wanner take it out for any way,,also if u want to put a air pod in can u just leave them out of the air box or would it suck in hot air and not cold,,
    Boonz's Avatar
    Boonz is online now the holden mechanic Boonz Maloo Boonz Maloo
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    the weird looking head is called a torx head and needs special torx bits to remove them
    VT Wagon
    Jul 2005
    i want to take it out to paint it and also thinking about getting a FIT type S CAI.. so it needs to come out evently
    Shounak's Avatar
    Shounak is offline The Kicking Horse Shounak GTS Shounak GTS
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    Quote Originally Posted by Swift Jimmy
    Hey all,
    They were just bolts on mine.. I used a spark plug ratchet to remove em..
    Shounak
    Always Right
    My Ride
    vt in progress
    Sep 2005
    You need a torx bit like everyone else said, can't remember what size it was t-27 or t-30 I think? One of the bolts near the wheel arch, on the outside of airbox is a prick to get at.
    DVS's Avatar
    DVS
    DVS is offline D̮̯͓͂͌ͤͬ̌ͣ̈ͧͩ̃͐ͩ͛̔̀͛̑ͯ ͎̞̜ DVS Executive
    VT V6
    JigSaw Puzzle Monkey Champion!
    Jun 2004
    I just pull it hard. dont need to unscrew it. There are rubber grommets that allow you to pull it off. The screw just stays in its place. Thats how i do it anyway.
    VT Wagon
    Jul 2005
    Hey all i tried everything like everyone said to try.. and quess what.. it came out !! that you all for your advice.. i'll post pics of what i did to it shortly.
    vp calais
    May 2006
    adelaide
    before u upgrade if that wont be for a while just mod it coz its 10 times better than puttin a pod on n u can get defected for it. just open the inlet up a lil more cut the plastic on the inside around the inlet hole. and put a hi flow filter in it does make a diff
    VT Wagon
    Jul 2005
    Here is the pics that i promised.. Soz about the quality taken with my mobile.. I thought stuff painting it.. I'll try that DIY cooled intake that is on this forum some were.
    What do you guys think? i didn't get to finish were the piping goes at the front cause it started raining.
+ Reply to Thread
  1. Removing the KAT
    By Egnitevt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-10-2007, 11:04 PM
  2. Removing VP Air Con
    By Cobez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2007, 12:58 PM
  3. Removing LPG
    By mattyJC in forum General
    Last Post: 17-02-2005, 10:17 PM
  4. Removing H/U from VN
    By VN_WA in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2005, 03:09 PM
  5. Removing Air-con
    By jamos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2004, 07:16 AM
