Results 1 to 7 of 7
Thread: Fuel Sender Unit
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    Default Fuel Sender Unit
    does anyone know if the fuel pump/sender unit from a vs commodore is the same as the vt?
    cheers,
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    VT Calais
    Aug 2005
    Hey, Apparently the actual fuel pump is the same, I'm about to fit a new fuel pump to my VT Calais that i bought for my VN a while ago, I have asked around and they have said it will fit. The issue im having is I can't actually see where the fuel center is under the car. Do anyone know if there is an access panel in the boot or somewhere else to remove the fuel pump (I have had a good look under the car, under the back seat and in the boot, but I might have missed something), or do u have to remove the fuel tank. Any info on getting the fuel pump outa the VT would be great....
    Cheers...
    vz wagon
    Mar 2006
    Vt u have to drop the tank, takes 5 mins on a hoist, lot easier than vn-vs tanks to remove.
    VT Calais
    Aug 2005
    Ok, well I replaced the Fuel pump in the VT today, I reckon the VN is heaps easier to do, but anyway The Fuel sender and Fuel pump in the VT are completey different to the VN's unit, so the info I was given was wrong (sorry for passing on wrong info). So after I pulled it all apart, I found out the pump I had from the VN was useless, and had to go get a new one. It wasn't to difficult to fit, just abit annoying. I hope this info helps.
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    Quote Originally Posted by zakess
    did the new fuel pump come with a new sender? or was it on its own?
    cheers,
  1. Fuel Sender MRA Unit??
    By MikesVT in forum General
    Last Post: 19-08-2006, 12:45 PM
  2. Fuel pump and sender unit
    By scojohara in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-03-2006, 12:51 PM
  3. fuel tank sender unit
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2006, 06:23 PM
  4. How to replace fuel sender unit!
    By chrishodge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-02-2006, 02:26 PM
  5. Fuel Sender Unit
    By micko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2004, 12:33 PM
