You could try using Holden’s Top Engine Cleaner. I use it often, works well. If your injectors are really bad it will only help a little. Do the ultrasonic cleaning if this is the case. Also check your leads, if there is missing. Also depending on how many Km's you may need new O2 sensors on the exhaust. They control the fine tuning of the fuel ratios. Also if you are using an oiled after market air filter, this can oil the MAF and distort air flow readings. Then there is how you drive your car on the highway. Ecotechs have a lean cruise mode, in easy terms, it makes the car use less fuel but only under certain conditions. See
>Here< for an explanation But generally don't use more then 45% throttle on the highway to save fuel.
