Results 1 to 5 of 5
Thread: Hissing sound from ventilation dials VT II
    VX commodore A4
    Sep 2005
    South Australia
    Default Hissing sound from ventilation dials VT II
    I am aware that there is a vacuum operated solenoid which adjust the ventilation settings behind the rotary control for defog/face/foot etc and hopefully it is only a hose which has come off.
    There is a constant hissing sound and the rotary control which adjusts defog or face etc settings does not work properly, since it is a constant hissing noise I would imagine it is a vacuum line leak.
    Has anyone had any similar problems?
    Update: If I push on the dial for a while it works......somethings buggered alright.
    VXII S Super6 Manual LPG
    Oct 2004
    Townsville QLD
    Definitly sounds like a leak.
    I had a similar prob, but turned out that the heater solenoid hose had been taken off. . . . .
    U probly got the same thing, hose has fallen off, busted hose or busted component. . . .
    Stoke my ego, click the scales!!!
    Stoke it!!!!
    LOVE IT!!!!!
    VX commodore A4
    Sep 2005
    South Australia
    Yeah, buggered component I think, the dial which adjusts defog/foot/face/recirculate, etc is hissing but stops if you push it together, I took off the dash garnish and had a look behind and could not see any wires missing but noticed the buggered part, and knowing my luck I'll have to buy the complete dial assembly
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    VXII SS
    Dec 2005
    NSW
    Quote Originally Posted by kinkbike_rider
    I had the same problem.... found out later it was the pod filter sucking in air...lol
    hahahahahaha
  1. Vt V6 hissing sound under light throttle
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-11-2011, 08:51 AM
  2. Ventilation selector kaput!
    By DYIer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2009, 06:09 PM
  3. low pitch hissing sound after removing headunit
    By Brycestro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2006, 11:32 PM
  4. VR Commodore - Hissing sound when Air Con switched on
    By wakesetter_boarder in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2005, 09:38 AM
  5. hissing sound VC
    By marky mark in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-07-2005, 09:08 PM
