Results 1 to 6 of 6
Thread: Vt Instrument Cluster
    Sep 2003
    Hi Guys,
    Can you swap an instrument cluster from a V8 into a V6 (and vice versa)?
    The dash is from a series I VT and will be going into a series I VT.
    Cheers,
    Naccas.
    Phil Guest
    I think they are both the same intrument cluster. I have owned a series I vt 5ltr V8 and use to drive a vt aclaim for work.. I am sure they are the same.. the only difference I could think of that might impact would be the redline limit on the V8 cluster.. it started at 5,500 rpm..
    Are you replacing a broken one with the V8 one?..
    Phil
    MaNiac_VP is offline Mr Moderator !
    VPII Calais
    Oct 2003
    Sep 2003
    Mine is a V6, and I was seeing if I could replace it with one from a V8.
    I wasn't sure if there was a switch on the back or similar to compensate for the tacho between the V6 and V8. I thought there was for earlier model Commodores.
    Cheers,
    Naccas
    VPII Calais
    Oct 2003
    The only switch that some older commodores had (on trip computer dashes) was the option of 60/80 L tank, for the working out of 'fuel remaining on the trip computer.'
    Putting a VT 3 window V6 trip computer dash into a V8 will give strange readings also like '1200 km left' for fuel remaining and the rev guage will be out all the time.
    The speedo may be as well, i think on the VXs and VYs they even changed the looms on the back of the speedo unit so that they cannot be interchanged with any units except their original ones.
    Sep 2003
    Thanks for the help MaNiac_VP and Phil.
    Much appreciated, has saved me a bunch of money.
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. Please Help - VT Instrument Cluster
    By Miss-E in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-11-2006, 02:32 AM
  3. instrument cluster
    By donwb in forum General
    Last Post: 06-05-2006, 02:28 PM
  4. VN Instrument Cluster
    By Waussie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-07-2005, 08:30 AM
  5. Instrument Cluster
    By diggler85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2005, 05:37 PM
