What is optimal oil change interval on 6 cyl VT II ? Every 5K ?
What about oil filter ? Every 10K or every 5K ?
What is better oil filter brand : Ryco (expensive) or Valvoline - or something else like AC Delco ?
Thanks.
Always do both oil and filter. 5k and 10k depends on how anal you are.
A lot of mineral oils get fouled after 5k. Semi-synthetic and synthetic oils should be changed abot the 10k mark. Some dealerships and oil companies say that Full synthetic oil is fine for 20k, but I'd never do it..
I use Ryco filters..
Ok - thanks Shounak. If you use good quality synthetic oil and a good quality filter like Ryco, and change oil every 10K, presumably the oil filter will be ok for 10K too ?Originally Posted by Shounak
Also, usual oil recommended by GMH is 10-30 I think ? Is any other suitable without risking engine wear ? What brand of synthetic would be best for 10K changes ?
Thanks again.
For the Ecotec I'd recommend Penrite 15W-40, I'm pretty sure they make it in Semi-synthetic. You could even go 10W-40..Originally Posted by nmldb
I wouldn't go 20W unless you've got over 220k's on the clock..
If you want a good full synthetic oil, try Penrite SIN, I've only heard good things about it. They make a 15W-50 oil, which would be perfect for you..
Full synthetics cost about $60-70, but the other ones would cost about $30..
And if you use Semi or Full synthetic, you will easily be fine for 10,000km (unless you do very heavy towing or dusty driving, or give your car hell)..
