I don't know anything about it but I have seen them on ebay and according to the person selling them, they can be fitted with the tranny still in the car.
Here's a link:http://cgi.ebay.com.au/Holden-Commod...QQcmdZViewItem
Has anyone done a servo swap ?
is it worth it ?
about how much did it cost you ?
is it something you can do at home without pulling the tranny ? (new to the autobox world , always had stick shifts before)so never played inside one much
one of the guys at holden told me it would fix the slop in the overdrive shifting and make it snappy shifting ? but being a computer controled box I wasn't sure
anyone know ?
*Goes and grabs servo and instructions from his room*
The trans doesnt need to be removed. You only have to remove the piston cover.
If anyone really wants ill type the instructions out.
Me personally am just going to get preston autos and diffs to fit it when they do the other work for me.
AirStrike![]()
I did it myself with basic tools in about 3 hours. I just followed instructions. While i was under the car i also did the force motor. Now chirps seconds when i put the foot down. Fitting the corvette servo only firms up the shifts slightly.
how much did they cost ?
Around $50-60.Originally Posted by grafxworld
AirStrike![]()
As per the link on ebay I gave earlier, $34.95 at the moment plus $5 postage.
so basically its a shift kit? it provides more oil into the trans makin a harder shift...if so thats a cheap shift kit
''I'd rather ROAR than WHISTLE''![]()
Originally Posted by DVS
how modified is ur car? ... to chirp second .. ive got a ecu upgrade in mine and im makin 160kw ... with a corvette servo will it cherp?
I have only got extactors, exhaust and F.I.T rockers. Servo alone wont make you chirp 2nd gear, you need to do force motor as well. The servo is 1 million times easier than force motor.Originally Posted by JohnniieeVS
I got mine from ebay $40 also bought some trans fluid to top up but you hardly loose any fluid. I couldnt believe how easy servo was to do, i was quoted $550 to get it done.
Thanks
DVS
um i did my servos 4 yrs ago
best thing i ever done
chirps into second easy and once even into 3rd in the dry
i kow ppl with shift kits and they feel the same but servos are cheeper way of doing it
mine was 180 fitted while getting service on trans
never had a trans prob wiht them in
would i do it again if i got new car hell yeah
ps.Servo alone wont make you chirp 2nd gear, you need to do force motor as well (um mines fine and chirps heaps)
Tell me how it made it chirp the 2-3 shift when the corvette servo only acts on the 1-2 shift?Originally Posted by daron.
AirStrike![]()
Originally Posted by AirStrike
you do the 3-4 gear change servo as well.....
it was the camber of the road and on a bend hehehe and it chirped into 3rd
yeah do them all
I know this champ, but he only changed the 1-2 servo.Originally Posted by VTPREDATOR
AirStrike![]()
I bought my 1-2 corvette servo of him and it's great! Been in there for damn... Maybe 4 or more years! It was one of the best things I did. I also turned up the box pressure and considering it has no shift kit... It shifted freakin awesome!!! Every gear change was solid and no soft slip when at WOT. Still after all this time and a shite load of extremly hard driving it's still behaves like the first day it went in.
Very happy and highly recommend doing this mod!![]()
the corvette servo shown here applies the 2-4 band. the band grabs hold of the reverse input drum, which is how you change to 2nd and 4th gears.
the larger apply area means the shift is made with more force and you it holds the band down harder.
the downside of a harder shift is it obviously loads the transmission a bit more, possibly wearing it faster but who knows by how much? probably not much as the corvette box is the same i would imagine so if it can handle it then so can the commodore one i would assume!
Most people/workshops I have spoken to suggest that the box may last longer, as there is less slip in the gear changes so the clutch packs wont burnout as quick.
AirStrike![]()
Actually improving the way an auto shifts to make quicker changes wears the auto less... but the trade off is it's harsher on you diff, axles and uni-joints.Originally Posted by jules
Disclaimer For The Reader ::
The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK or do not use the information at all.
I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
I am NOT a Mechanic. You have been warned.
what you guys said makes sense, now that i think about it again..
