Results 1 to 5 of 5
Thread: VT Fluid question
    99 VT Berlina II sedan
    Jun 2005
    Victoria Park
    Default VT Fluid question
    Hey guys,
    Just bought a Series 2 Berlina Sedan and was wondering:
    Whats a good quality motor oil to use?
    Radiator Coolant?
    Brake Fluid(ABS brakes i think)?
    Transmission Fluid?
    i used distilled water to top up water dont i?
    Also does running a tank of premium every now and then benefit the life of the motor as it only has 75,000km's on it. And i want this baby to last.
    Shounak's Avatar
    Shounak is offline The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    Engine oil - Penrite 15W-40 - Semi Synthetic
    Brake Fluid - Penrite Dot 4
    Tranny - Castrol Dex 3
    Top up with a 50/50 mixture of Coolant (the one in your system) and distilled water..
    Using a tank of premium every now and then will have no effect at all. Neither good nor bad..
    The existing petrol in the tank will drag down the RON of the premium you're pumping in. It takes about 5-6 tanks of premium to flush out all of the other petrol already in the tank.
    Run on one or the other, otherwise, no point..
    Shounak
    Always Right
    My Ride
    Jun 2005
    Victoria Park
    VX Executive S2
    May 2006
    Frankston South Vic
    The most important thing is to change the fluids and filters etc regularly using good quality products, Everyone has their own preferences, I only use mobil products, mobil 1 10w30, and don't forget the coolant tabs for the water pump. The service intervals are fine for brake fluid, coolant and engine oil, (If using mineral engine oil change at 5,000). but i would change trans fluid every 40,000, diff oil and power steer fluid every 100,000.
    Andrew
    Hairy Eater's Avatar
    Hairy Eater is offline Banned
    2000 VX Executive V6
    Nov 2005
    Queensland
    i use shell premium since i bought my VX but so far have only used about 5 tanks..... i tested my 1990 Nissan Skyline over a 6 month period (mostly do city driving) and i averaged 16 miles per gallon....... changed to premium and did another 6 month test and got 21 miles per gallon....... hard to believe... more expensive fuel but more miles ( kilometers) per dollar than standard unleaded... my daughter tried the same with her ford raider.... same result as me.... further kilometers on $40 fillup on premium than $40 fillup on standard....
  1. Leaking Fluid..
    By Lukie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2010, 02:06 PM
  2. Brake Fluid... Which DOT?
    By VT Dave in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2007, 07:33 PM
  3. P/S fluid and diff oil
    By vs_dumped in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2006, 04:28 PM
  4. Brake Fluid and Auto Trans Fluid.
    By Melchior3 in forum General
    Last Post: 20-02-2006, 11:49 AM
