+ Reply to Thread
Results 1 to 14 of 14
Thread: vt brake pads
    xu1au Guest
    Default vt brake pads
    can any 1 tell me what break pads dont sqeak,,i got mine checked out on last service and all my breaking stuff in good nik even pads,,not sure what brand tho,,,i had bendix in my old vc commy and they didnt sqeak at all,,when i break it sounds like some 1 sqeezing a cat.
    VY Calais V8
    Jun 2005
    i have bendix ultimates on mine, great pads but they do start to squeal under constant heavy breaking and dump $hit loads of brake dust onto the rims. part from them the pads i had on the car previously which i think were the holden pads, were great round town for pulling up but sucked at highway speeds.
    accentstencil's Avatar
    accentstencil is online now Donating Member accentstencil Maloo accentstencil Maloo
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I have Bendix Advance on the front, hardly any dust and no squeal. I forget what I have on the back, but lots of dust and lots of squeal if I don't hose all that dust out of the calipers regularly. So I think the dust and squeal are related.
    VE SSV
    Sep 2005
    Perth, WA
    i use bendix advance all round and they dont sqeak.
    the Bendix Ultimates are a harsher brake compound and do tend to chew your discs quicker than the Advance mainly because they are designed for high performance
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper WAGON MAN Calais
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    I also have Bendix Advance all round. Minimal dust , No squeeling either.
    The Bendix Ultimates are a better pad and a harder compound because they are a high preformance pad.
    It would be best to have slotted rotors (or better )when using this type of pad to achieve maximum braking preformance.
    Shounak's Avatar
    Shounak is offline The Kicking Horse Shounak GTS Shounak GTS
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    I have Bendix Advance.. Good shit..
    No dust. No squealing. Does just fine for my general day to day braking.
    I have no complaints whatsoever.
    Shounak
    Always Right
    My Ride
    Have moved up to VE SS
    Jan 2006
    SYDNEY
    Again bendix advance but if you want something else you can't go past the Protex ceramic pad it has a full pad face and doesn't squeak and minimul dust bought from race brakes sydney for $50 a set 0296091101 awesome
    VT II Berlina Wagon
    Jun 2006
    Default Pads......
    I always thought that ceramic pads needed upgraded rotors ? Might be wrong. Original rotors arn't much good anyway.
    Anyway, I've used a brand of pad called "QFM" (Queensland Friction Material). Not cheap but no problems at all in over a decade of use on various cars, including a VL and VT II.
    Personally, I'd pay a bit more and upgrade those rotors. Some good ones on eBay.
    Good luck.
    ScottB_33's Avatar
    ScottB_33 is offline Go Hard or Go Home ScottB_33 Executive
    VTII Berlina Supercharged
    Oct 2005
    Nowra
    There is another choice now in Bendix have brought out a pad called Bendix CT. These pads have a titanium bedding in strip fitted as standard to address the issues of pad bedding in and noise. Dust is also a non issue now with these. Try them next time and I'm sure you will be impressed. I fit them all the time when servicing a customers car.
    VE SSV
    Sep 2005
    Perth, WA
    Quote Originally Posted by ScottB_33
    i just got a set for the front of my car and they are great.
    they call them Bendix General CT.
    VY II SS
    Jan 2006
    Warwick
    Quote Originally Posted by DeanoVT
    yep, i got the CT's all round and love the performance of braking. have never heard a squeel at all and never have dust on my chromies.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep wrx884 Caprice
    VT Commodore Exec/5L VP Calais
    Mar 2006
    VTS Commodore
    Nov 2005
    hi my breaks have just started squeeling as wel does this mean i need new pads? or rotors? how much am i looking at for a set of bendix advanced pads?
    thanks
    wrx884's Avatar
    Mar 2006
    Quote Originally Posted by Sebastian
    thanks
    Do they squeel while ur driving not pressing on the brake pedal at all?? if so its prolly just ur indicators on the calipiers tellin u ur brakes r gettin low and need replacing if not and its only wen u brake either u got a poor set of pads on or ur rotors have started warping then yer id suggest getting them machined
+ Reply to Thread
  1. QFM Brake Pads
    By gslrallysport in forum GSL RallySport
    Last Post: 12-08-2011, 02:39 PM
  2. How many k's from brake pads?
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 07:47 PM
  3. Brake pads changes.
    By Krustyone in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-07-2006, 10:02 AM
  4. Brake Pads
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-10-2005, 07:53 AM
  5. Brake pads
    By nervesplit in forum General
    Last Post: 11-12-2004, 05:31 PM
