Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VT - VX Holden Commodore (1997 - 2002)
VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 28-07-2006, 09:04 PM
TigerVX's Avatar
Ride: 2000 VX Commodore
Trade Rating: (0)
TigerVX Executive
Default Check Thermostat and Coolant Change
I'm going to change the coolant on my VX next week and I have a few questions.
1 - Is draining the existing coolant via the lower hose and knock sensors, then flushing the system via the top radiator hose the best way to do it?
2 - Does flushing the radiator that way also flush the heater core?
3 - Does the thermostat need to be removed to check if it is still good or are there other ways to know if it's buggered or not?
Thanks.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 28-07-2006, 10:58 PM
accentstencil's Avatar
Donating Member
Ride: WH II Caprice, 5.7
accentstencil Statesman
Yes that is correct. But you temporarily put the knock sensors back in while flushing, then remove them again for the final drain. It will flush the heater core providing you have the heater control set to hot. Make sure you use a coolant that contains ethylene glycol and not an inhibiter. I use Tectaloy V Plus which conforms to GM-H factory specifications for the Holden Commodore V6 engine. It's not cheap but then neither is the holden coolant. I used to use Nulon but was advised against it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
HELP! how do i change the coolant!? judoman VR - VS Holden Commodore (1993 - 1997) 3 01-07-2006 05:34 PM
how to change thermostat? vn6pwr VN - VP Holden Commodore (1988 - 1993) 6 12-03-2006 08:34 PM
Coolant Change fitzy2005 VR - VS Holden Commodore (1993 - 1997) 7 10-12-2005 09:39 AM
how do you change the thermostat daniel VR VR - VS Holden Commodore (1993 - 1997) 4 21-08-2005 05:50 AM
Coolant Change DJ Majah General 12 29-04-2004 10:22 PM
Personal Finance | The eBay Song | Loans | Payday Loan | Books | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
