Results 1 to 18 of 18
Thread: Supercharger Oil?
    VX Series 2 "S" Pac Supercharged
    Jul 2006
    Default Supercharger Oil?
    Ive heard that S/C's take oil. Is this true. Also how do i check it and what oil do i use when i replace it. VX series 2 S/C. Thanks.
    Jul 2006
    wetwork65's Avatar
    wetwork65 is offline A wet business
    VY Berlina V8 & VZ Adventra LX8
    Mar 2006
    With the goblins in South West WA
    Supposed to be OK for life!
    But it is worth checking. Listed in the 100000 service.
    I checked mine at 98000 km - found it needed two bottles (120 ml each) to bring the level up correctly. Total I believe is 2.5 bottles - thus mine was very low - I have a slight leak at the shaft.
    Holden dealer is $34 each! although have seen it in USA websites at $US7 each.
    Am now looking at a rebuilt snout from USA.
    Good luck.
    VY Calais V8
    Jun 2005
    Eaton (the manufacturer of the charger) say that the oil in the charger is good for 100,000 miles (160,000 kms), i had mine changed at the 160,000 service, and even then the mechanic said the oil was fine. needed 3 and a bit bottles of the oil and like wetwork65 said it aint cheap at around $30 for a 250ml bottle!!
    Jul 2006
    wetwork65's Avatar
    Mar 2006
    seano Guest
    I was also under the impression that the oil did not need checking/topping up, I swear I read somewhere that it was a fully sealed unit and required no maintenance. Why would they say that if its not true?? My 01 VX has never been checked and its at 130,000 I think Ill check it today.
    thanks all
    Charge_Me_Baby's Avatar
    Charge_Me_Baby is offline <--- Ooops
    VX1 S SUPERCHARGED
    Mar 2007
    Maybe this is why my one sounds a bit dry on start up and at high revs.
    stupid question (i know there aren't no stupid questions just stupid people ): how do you refill it/ check it without losing oil?
    VX S SUPERCHARGED
    wetwork65's Avatar
    Mar 2006
    Take a look at the picture a few posts ago (thanks six-shooter for this pic). When you take the screw out there should be no loss of oil.
    The oil should be up to the bottom of the thread - may need a torch to help see inside.
    VX II Supercharged S pack
    Dec 2006
    Quote Originally Posted by seano View Post
    thanks all
    Well they say it because it probably is true in a perfect world. But in the real world seals get old and start to leak.
    Visit my photography site www.lcimagery.com
    VX1 S SUPERCHARGED
    Mar 2007
    Quote Originally Posted by wetwork65 View Post
    I looked at the pic. Just thought that seeing its the drain and fill hole that oil loss might occur. observation.
    VX S SUPERCHARGED
    VX1 S SUPERCHARGED
    Mar 2007
    wetwork65's Avatar
    Mar 2006
    VX1 S SUPERCHARGED
    Mar 2007
    Thought so. I was trying with one this morning. It's certainly on tight.
    Thanks for that.
    VX S SUPERCHARGED
  15. #15
    08 VE SS-V 6.0Lt V8 SEDAN
    Mar 2006
    ***** Please Note *****
    Make sure that the engine/supercharger is cold before opening the S/C Oil plug. If its hot, it can splurt hot oil and steam out the hole (Which stinks and will cause oil loss).
    Just a warning for all.
  16. #16
    VX "S" series II S/C V6
    Jun 2010
    For the oil I asked an Auto 1 shop, and they said it will take Syntrans 75W/85 (castrol i think) these come in 1 litre bottles @ $25. They had to ring around and find out and seemed geniune helpful. This sounds like a cheaper and get more for your buck option than Holden dealerships.
  17. #17
    Jun 2010
    Also the procedure is laid down in Gregory's No 273 (commodore 1997-2002)
  18. #18
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    Quote Originally Posted by Wayno VXII View Post
    sound pretty good, is it 100% safe????? holden was 30 or $40 for a tinny little bottle and ya need 2
LinkBacks (?)
  1. SC 14 supercharger
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2006, 01:04 AM
  2. V8 or supercharger
    By HVXII in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-09-2006, 11:21 PM
  3. supercharger on 6 cyl..
    By tougHnA in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-04-2006, 06:01 PM
  4. supercharger for vx
    By VX_GIANTZ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-01-2006, 11:12 PM
