Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: VT Engine Mounts
    VT2 SOCOG Exec 9C1
    Dec 2004
    Default VT Engine Mounts
    Hi all,
    Just had my 120,000 service.
    Last one before the extended warranty runs out (Damn you AON)
    They found that my engine mounts are sagging and need replacing ~5mm drop supposedly. Sort of expecting I suppose given the FE@ and the firmer ride. Two questions,
    1.What else should I make sure they check as part of the repair. What else could they **** up?
    2. Whenwe tried toget the Warranty reapir approved AON said it won't cover it as it is fair wear and tear! What do you guys think. I have had this 9C1 since new.
    AOn have been shifty lately saying my latest link rod and fron sway bushes were fair wear and tear-even after two replacments in the past and nut putting VX components inwhich were stronger. Shows you you need to watch extended warranties, though it has paid for itself in the past so far.
    Subsiste Sermonem Statim
    mistaken's Avatar
    mistaken is offline ... pimpin it VT stylez
    VT
    Jun 2005
    My VT S1 has sagging mounts aswell. Holden quoted me $450 for supply and fit - bit pricey IMO. Picked up a pair of mounts at Repco for $96 , and mechanic mate will be fitting them for $150.
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    One of my engine mounts have sagged, and the sump is hitting the chassis under it... which has become a RWC prob. Picked up a set for $40 each, too easy There are no mods on my car so i guess its fair wear and tear for me... after 180k km;s tho :P
    VT2 SOCOG Exec 9C1
    Dec 2004
    I got quoted about $360, allowing for Morning Tea for the Mechs. $95 for each mount- though should get them at trade.
    Apparently most of the work is the centre one which is under the aircon.
    VY Calais V8
    Jun 2005
    mmmm this thread just reminded me my drivers side on needs replacing... pedlers told me some 3 months back when it went in for a suspension check it was badly sagging...
    more money to spend on the car
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    Quote Originally Posted by don0xer
    where did ya gte for 40 bux cause mines broken and needs replacing
    VT S
    Jan 2005
    I had vibrations through steering wheel & drivers seat & always thought it was an idling problem but found after looking at the mounts from underneath car they were sagged so much the pin that goes through the mount were actually sitting on the chassis,
    after changing the mounts now it is idles sooo quiet, & no vibrations whatsoever, best $110 I ever spent.
    Btw, Repco has them for $55 each aftermarket.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Jst a quick question...
    How often should getting this sorta thing be done??
    Like i got my car lowered heaps so there is more strain on the mounts...
    VT S
    Jan 2005
    Just look at mounts from under car & if the pins that go through mount are close to or sitting on chassis they need replacing,
    there should be at least 15mm clearance between pin and chassis.
    Also sump should be higher than K frame by 10mm or so, mine was below k frame by 5mm.
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    VT executive
    Dec 2005
    I just did mine, they were badly sagging, 135000km and fe2 springs. Paid $86 for a pair of aftermarket ones, and installed myself, bugger of a job though.
    98 VT With S Pack
    Dec 2006
    Just had my engine mounts redone. They were cracked and the engine was sitting on the plate underneath.
    Cost me $40 for each mount, and a mate fitted them @ $30 an hour, took him 3 hours to do
    MY10 VE SS-V wagon
    May 2005
    VT S/C SIX
    Jun 2006
    Quote Originally Posted by webwombat View Post
    what they look like? could someone take a photo of them?
    Big chunk of rubber about 50mm thick from memory did mine at about
    130 000kms
  15. #15
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
  16. #16
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by AttaBoy View Post
    Can bad engine mount cause rough idle??
    If the mounts are bad enough and sitting on the metal pins it can seem rougher as you can feel all the vibrations from the engine because the rubber isn't absorbing the vibrations. But bad mounts won't make you car idle any different.
  17. #17
    VT executive
    Dec 2005
    MY10 VE SS-V wagon
    May 2005
  19. #19
    VT Berlina
    Oct 2008
    Smile Engine Mounts
    Holden Dealer replaced my 4mm sagging 2 fluid engine mounts today and changed the Automatic Transmission oil. Now the car goes better than a mercedes Benz honestly, no more scrapping noises when cold. I think it was the Engine Mount making the car sound like this I could feel the vibration down on the drivers side floor. $478.
  20. #20
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Mine sagged, sump resting on cross member, lots vibration. Jacked up engine and slipped in a 6mm packer under each mount, all fixed, ...cheaply!
    Tight wad Pablo
    LOL
  21. #21
    VT Acclaim
    Aug 2008
    Okay so wheres the best place to buy a new pair of these lads?
    i can't find anything better than that Repco price, hopefully they still sell them there.
  22. #22
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    i replaced my mounts 6 months ago however it was about 6 months to late as the sump had been rubbing thorugh on the k-frame. there is now a 5mm deep scrape in my sump so if u have bad mounts replace them asap.! ...does anyone know if you need to rreplace the sump with a chunk outa it for a RWC?
  23. #23
    VT Acclaim
    Aug 2008
  24. #24
    VT Commodore Berlina Wagon
    Mar 2010
    Don't forget that the factory V6 engine mounts are hydraulic. They are filled with a damping oil and after 200,000 k's or so the rubber cracks and lets out the oil. This oil filled factory mount is very effective at damping the V6 vibrations, particularly at idle. But yes, they are about $130 each. Your cheaper aftermarket mounts are solid rubber and whilst certainly are better than a collapsed mount, they are not as good as a factory mount. The factory mounts will typically give a creamy smooth idle with basically no vibration detected inside the car. Whereas the solid rubber one's you still get a little vibration coming through to the body. It's up to each of you which way you go, just make an informed decision not soldey based of price.
    lpme126
  25. #25
    VX L67
    Dec 2007
    Got quoted 150 Labour, And i get the parts trade 114 for 2 engine mounts and transmission mount... FTW
  1. engine mounts
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2009, 05:28 PM
  2. Engine MountS!!!!
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2007, 02:43 PM
  3. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  4. Engine mounts
    By VSAccCom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2005, 11:23 AM
  5. Engine mounts
    By RockyC in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2005, 12:21 PM
