Results 1 to 11 of 11
Thread: Elexctric window wiring for VX sedan and VU Ute
    VE SSV
    Sep 2005
    Perth, WA
    Question Elexctric window wiring for VX sedan and VU Ute
    Hi all,
    need some info for a couple of my friends.
    one has a VU ute and the other a VX sedan.
    none of them has the wiring harness in it near the gear lever.
    basically i need the pin out configuration for original wiring of the windows
    ute (2 door wiring obvioulsy) and sedan (4 door wiring).
    has anyone done this and if so how did you do it?
    or has anyone got a wiring diagram for this??
    Thanks in advance.
    Dean
    VXII Commodore Exec
    Feb 2004
    Is the plug actually located there, or is it a little bit further back?
    Around three years ago (not long after I bought my '02 VX Exec - I bought it near new), I pulled apart the area around the gearstick to sort out an annoying squeeking sound.
    Between the seats is that big storage unit "thing" - the thing with air vents attached at the back. I pulled the entire thing out, as well as the gearstick surrounds.
    I found the little mobile phone wiring (left of the geastick), but underneath the big storage unit I found an electrical plug.
    Is that for the electric windows?
    One day I do plan to install electric windows into my Exec, but only if the wiring is already there...
    - Gareth
    VS STATESMAN - VK GROUP A/3 Replica (Project)
    Jun 2006
    Do you know if the plug would be there for the VT Series 1???
    Many Thanks
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by calaiscruiser76 View Post
    Many Thanks
    The plug was there on my VT series 1 Acclaim. I just put electric windows in 2 weeks ago. I needed to buy the door looms though.
    Jun 2006
    Quote Originally Posted by accentstencil View Post
    I lifted the shifter surround and could only see 2 yellow looms?? Do you think the little sucker may be hiding under there???
    Thanks,
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It's a big plug , mine was just sitting there, I didn't have to search for it. You can also check where the power window relays and fuse go, if you can see the connectors in there and they are not just empty holes, you should be wired up.
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    im after a wiring diagram or pinouts too (for 4 door) because I want to hook my aftermarket electric window kit up to genuine switch pack.
    My VX has the switch packs wiring harness (plug) there under the gear knob, not that it'll matter if Ive got the pins for the relay or not because I wont be using it, but I need pinouts or a wiring diagram so I can wire up the switchpack to my window kit so I dont have to use theres!
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Y2kGoofball View Post
    Why don't you use the existing relays and replace the door looms for ones for power windows and just hook them up to you new regulator motors? That way you BCM controls the windows.
    VE SS Ute, 94 Swift Cino
    Dec 2004
    Lennox Head NSW
    I will have a look on Monday at work and see if i can geta wiring diagram for both the 2 door and 4 door, then if i can post it i will, if not may have to email it.
    Mick
    VE SSV
    Sep 2005
    Perth, WA
    Quote Originally Posted by mjm4676 View Post
    Mick
    its all good champ...my mate found someone who knew how to do it.
    Torquative's Avatar
    Jun 2005
    what about me ... I dont know!!
    accentstencil, I assume this method would involve buying the door wiring looms from Holden, which has got my interest because I have priced that up before.
    My only question is where do the wiring looms connect too? Ive never really followed through on them to see where they go, I'm assuming they plug into the BCM or similar, and it would be a matter of replacing the existing wiring loom for one that includes power window, and unplug the old and plug in the new at the computer?
    The thing is Ive stripped the doors down before and found theres no wiring looms to the door what so ever for power windows (I have once had someone suggest the wiring is already there waiting for the regulators to be connected), but there is a switchpack plug and pins for the relay (I'll double check the latter tho just to make sure)
    Sorry to ask so many stupid questions, you seem to be the man in the know!
  1. VN Calais Sedan Power Window Motors into VS Wagon, Any problems?
    By nugatory in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2007, 11:00 AM
  2. Wiring loom (towbar) 2000 VX sedan
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2005, 09:48 AM
  3. Electric Window Wiring
    By crowzy in forum Electrical Wiring / Questions
    Last Post: 19-11-2005, 01:53 PM
  4. power window wiring
    By crainy in forum Electrical Wiring / Questions
    Last Post: 19-07-2005, 08:34 PM
  5. Electric window Switch wiring
    By Rogue-VL in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-07-2005, 10:50 PM
