vx fault codes
T
trevcom
Guest
Hi all ..first time post... can someone tell me if i can access fault codes on this model or do i need diagnostic tool Am having start problems when car is hot & stopped for a short time & will check CAS any other suggestions
trevcom
BOGANV8
I gotta V8 whoot whoot
44
Armidale
VX 02 SS LS1
i think ya need tech 2 machine from holden to check any fault codes in the system
Someone else can confirm :thumbsup: :thumbsup:
TigerVX
2000 VX Commodore
Check out this thread for details on how to check fault codes.
http://forums.justcommodores.com.au/showthread.php?t=23665
Error codes on a VX are show in four digits rather than two digits.
So a code 12 (all OK) is shown as 0012.
eg. Ten flashes, Ten Flashes, One Flash then Two Flashes. (Ten translates as a zero)
BOGANV8
44
Armidale
VX 02 SS LS1
will this work on a V8 5.7 Ltr
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
no the V8 uses a different data format & needs a scan tool
Rob
BOGANV8
44
Armidale
VX 02 SS LS1
:ranting: :ranting: :ranting: :ranting: :ranting: :cry: :cry: :cry: :cry: :cry:
Well that sucks then
WinterVX
N/A
10 flashes represents 0 does it not?
If so, what does code 00 stand for?
Edit:
Never mind, looks like its 00 12 system operational :)
TigerVX
2000 VX Commodore
Edit:
Thats right. The code you are getting is 0012 (all normal).
VX codes are displayed as 4 digits. I don't know why though. Seems quite stupid to display four digits when you only need to use two.
For ages I thought I was getting a fault code of 110 (two sets of ten flashes) until Dr Bob explained it.
lout
60
Langwarrin Victoria
Thanks tigervx for clearing that up, I thought I had the only weird VX that flashed 20 before the 12
bucketeer
58
VX Exec Wagon
Why didn't I think of that ?
Thanks Tiger,
I think you PMed me ages ago when I posted the same "problem", now you've cleared the confusion and I can get to sleep at night again, all seems so simple when you look at it from outside the box
Weel done!
Bucketeer :w00t:
