+ Reply to Thread
Results 1 to 6 of 6
Thread: Vt camber
    Oct 2006
    Default Vt camber
    Hi all,
    First post, (Newbie). I have just purchased my first VT series 1 Commodore, Low K's 115,000 and in great nick. Been a Ford man for the last 20 years, and I'm a bit worried about the rear wheel camber. It has been lowered with Pedders suspension and munroe shocks. It sits on 17" wheels and the camber seems off a fair bit.
    The question I have is:
    Will this effect the handling and damage the rear end at all. I have noticed some VT's on the road with the same problem, so should I fit a camber Kit? ( $400 or so), or should'nt I worry about it. Thanks for your help.
    By the way, my car is heaps more powerful than the old EA.
    daron's Avatar
    daron is offline wizfiz daron Berlina
    VE SSV
    Mar 2006
    adelaide
    yes get a camber kit
    if you dont youll oly scrub out your tyres and over 5 yrs you will end up paying way more for tyres than the camber kit
    i did mine 5 yrs ago (was under 100 bux then) and best thing i ever did
    ive never had a tyres scrub out
    peders did mine
    knowledge_is_power's Avatar
    knowledge_is_power is offline Quest for Cognition knowledge_is_power Berlina
    VT SII V6 A4
    Oct 2004
    Nth Brisbane
    Yes, get the Camber/Toe kit done as it does wear the inside of the tyres out fairly quickly (as mentioned previously by daron.)
    Also you will find that you have a little less traction when trying to take off. This traction problem is exaggerated in the wet.
    Jezz
    VN Calais
    Apr 2006
    Just a quick question with the camber kit. (dont know alot about it) i am getting mine done on wednesday by pedders and was asked if want to do both(2 kits) or just one. is that meaning top and bottom? and also if that is the case is it a good idea to get them both done
    daron's Avatar
    VE SSV
    Mar 2006
    adelaide
    VT SII V6 A4
    Oct 2004
    Nth Brisbane
    Its normally referred to as inner and outer kits. Pedders don't normally like doing both as there is issues with diff and CV's wearing. The additional wear is due to incorrect adjustment. You use the inner kit for Toe and outer for Caster I believe (it could be the other way round so check) and If your getting it done, do both. I have had both installed and while it has helped it would benefit from more adjustment which I can't get.
    Jezz
+ Reply to Thread
  1. camber kit on vt
    By jezzaaa in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-07-2010, 05:45 PM
  2. camber kit
    By Noy in forum General
    Last Post: 23-01-2007, 06:03 PM
  3. !!!!!!camber Kit!!!!!!
    By nocky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-07-2006, 12:34 PM
  4. Camber kit
    By greatone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-05-2006, 07:14 PM
  5. VX camber kit
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-08-2005, 06:01 PM
