Results 1 to 22 of 22
Thread: Warning Beeps when started
    VT SPac
    Oct 2006
    Default Warning Beeps when started
    Hi Guys im only new to this forum and would like to request some help.
    I recently brought a VT Commodore S Pac and am wondering why everytime i start the car after about 5 seconds it beeps 3 times at me than 3 times again. I have read the manual and there is no warning lights on at all when its beeping. I rang the dealer and he thinks that all VT's do this which i think is not right as my mum also has a VT this doesn't beep. Any ideas would be muchly appreciated.
    NaZ
    VE SSV
    Sep 2005
    Perth, WA
    it shouldnt do that.
    do the indicators flash as well cause if someone breaks into a vt/vx it will beep and flash lights.
    i would assume your car isnt being broken in all the time so i would say its returning a faulty signal to the bcm....
    straight from the book.
    "If you wish to find out what set the alarm off, carefully watch the security light, located above the trip computer switches in the dash:
    2 flashes = bonnet
    3 flashes = boot
    4 flashes = passenger door (front or rears)
    5 flashes = drivers door
    6 flashes = hot wire attempt"
    if you have a alarm fitted then this post applies to your problem...if not i recommend you take it down to holden and see if any fault codes are appearing.
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eagle Vale, Sydney
    Quote Originally Posted by NaZdOg View Post
    NaZ
    Sounds like the airbag warning chime. Does the airbag light come on with all the other warning lights when you turn on the ignitiont? If not you may have a blown globe. A chime is usually accompanied by a warning light.
    The airbag light is the one under the power light.
    Attached Thumbnails Attached Thumbnails Warning Beeps when started-000_0229.jpg
    vtcommylova Guest
    hiya i also have the same beeps when i turn on my ignition im not sure on why my VT does it also
    WH II Caprice, 5.7
    Jun 2005
    Eagle Vale, Sydney
    Quote Originally Posted by vtcommylova View Post
    Do any warning lights come on when it beeps?
    VX Executive S2
    May 2006
    Frankston South Vic
    Is it a chime beep or the horn beep, if chime sounds like airbag or seatbelt tensioners
    fabz's Avatar
    fabz is offline I Can Do Science Me
    Blown V6 VT commodore 5 speed
    Jul 2005
    In My Car!!
    I would say its the air bag thats making the noise. Check the connectors to see if there loose
    .:Blown VT V6, DAJ37:.
    VXII S Super6 Manual LPG
    Oct 2004
    Townsville QLD
    Go take it to Holden and get them to hook it up to the Tech2.
    Only way you'll find out what it is.
    Stoke my ego, click the scales!!!
    Stoke it!!!!
    LOVE IT!!!!!
    VT SPac
    Oct 2006
    I have found that the Airbag Light doesn't seem to turn on at all when started as shown in dash light pic. I am thinking that the led behind it isn't working and that the warning is the Airbags. Does this usually mean they need a service?
    VT SPac
    Oct 2006
    WH II Caprice, 5.7
    Jun 2005
    Eagle Vale, Sydney
    You should get it checked out and reset. Also replace the airbag warning globe.
    Oct 2004
    Townsville QLD
    Not all errors will illuminate a globe.
    Have u gotten it checked out yet?
    Stoke it!!!!
    LOVE IT!!!!!
    VT SPac
    Oct 2006
    gettin it checked out on wednesday will let u know how it goes. do you know whether this should come under dealer warranty?
    2002 VY SS Ute 5.7
    Aug 2006
    what the tech 2 worth to get the airbag light reset coz mine lights up and beeps
  15. #15
    WH II Caprice, 5.7
    Jun 2005
    Eagle Vale, Sydney
    Quote Originally Posted by deserthead View Post
    His airbag light is not lighting up as it should when he turns the ignition on, so Iim sure the globe is blown.
  16. #16
    WH II Caprice, 5.7
    Jun 2005
    Eagle Vale, Sydney
    His airbag light is not lighting up as it should when he turns the ignition on, so I'm sure the globe is blown.
  17. #17
    WH II Caprice, 5.7
    Jun 2005
    Eagle Vale, Sydney
    Sorry about the double post. Tried to delete one but was unable to for some reason.
  18. #18
    VN Calais
    Apr 2006
    do the vts beep if your odometer for the service check (as in serviced every 5 - 10,000km) hasnt been reset and it still thinks its due?
  19. #19
    Oct 2004
    Townsville QLD
    Nah not all do, a mate had his airbag module, I think it was this, was from a Berlina, his was an S and everytime he started it it would beep bout 5 times. No lights. Holden Tech2'd it and programmed it, he had no worries since.
    Younglion, it cost me 60 bucks to get my 3 window dash programmed to suit my car wen I swapped it for the single window. Shop around between dealers, you'll get a different price from each.
    Jonesy, I dont think they do, look in ur cars handbook, it should tell u how to reset it, or do a search of the forum and there r plenty of threads round on how to do it.
    Stoke it!!!!
    LOVE IT!!!!!
  20. #20
    VX Exec Wagon
    Nov 2006
    ive got a similar one - three beeps (they get higher pitched -like beep bleep bleeeep ) three times about 5 secs after starting in the VX. I was guessing its cruise starting up - didnt think holden was friendly enougth to make a warning tone interesting!
  21. #21
    WH II Caprice, 5.7
    Jun 2005
    Eagle Vale, Sydney
    Quote Originally Posted by stncld View Post
    That sound like the air bag warning tone. Do you get the warning light as well?
  22. #22
    VX Exec Wagon
    Nov 2006
    nope. goes out as it should.
  1. Airbag beeps
    By simso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-11-2006, 01:38 PM
  2. Computer beeps when I start car (not fuel warning)
    By HsvMan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2006, 09:11 AM
  3. VN Calais beeps when started?
    By Wesleyrpg in forum Electrical Wiring / Questions
    Last Post: 18-12-2005, 07:24 PM
  4. Beeps VR V8 Calais
    By jale in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2004, 01:13 AM
  5. It Beeps At Me?
    By Robbie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2004, 11:06 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
