Results 1 to 4 of 4
Thread: intermitant transmission problem
    VT2 ss
    Jan 2006
    Default intermitant transmission problem
    The autotransmission in my VT II SS started to play up.
    70 % of the time it is fine and changes the gears at about 2000rpm
    at normal driving but sometimes it is changing the gears much later (4000rpm with the same amount of accelaration)
    and I have to take the foot of the accellerator for it to change.
    When this happens and I take the foot of the accelerator and roll down a hill the engine warning light comes on and goes off when I accelerate.
    I took it to holden to check the computer log but it came up clear.
    I put new transmission fluit (dextron 3) and filter.
    Should I be using different fluit ?
    Thanks
    achimw
    08 VE SS-V 6.0Lt V8 SEDAN
    Mar 2006
    You may have a problem with your shift solenoids. I had a similar problem on my VS Trans. It would stay in 1st for ages and then suddenly change into 2nd. Took it to a good transmission place and they replaced the Shift 1-2 Solenoid and all was good.
    Not a big job. Just requires them Dropping the Pan, and Changing the Solenoid. Maybe they may have to remove the Valve Body. It shouldnt cost anymore than $300-400 in total.
    Hope this helps.
    VT2 ss
    Jan 2006
    The problem is the shift between all the gears and the engine seems to idle a touch faster.
    When stoping in drive it uses 2.8-3.2 litres/hour when the transmission plays up and when normal 2.2-2.6 litres/hour.
    Thanks anyway
    achimw
    VT_Boi's Avatar
    VT_Boi is offline VT Holden By Design
    VT Holden By Design
    Aug 2006
    Sunshine Coast
    Solenoids need to be changed by the sounds of the problem. Good luck I had my car off the road for 3 weks due to a auto problem, which took them ages to find out what it was.....turned out to be the valve leaking.
    Then The Boys Light Up.
  1. Transmission problem....i think...
    By Billo55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2007, 09:55 AM
  2. VR transmission problem
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2007, 02:32 PM
  3. VN Intermitant stalling/won't start
    By bido1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-09-2006, 05:06 PM
  4. Problem with transmission :(
    By bad_boyz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-09-2004, 04:18 PM
  5. intermitant engin fail
    By Spin in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-08-2004, 01:47 PM
