Results 1 to 5 of 5
Thread: Supercharged VT/VX on LPG
    May 2004
    Default Supercharged VT/VX on LPG
    I'm thinking about buying a supercharged VT/VX commodore. Only problem is I want to convert it to straight LPG but am a little concerned as if it backfires it could destroy the supercharger. Is anyone running a supercharged commodore on LPG? If so what configuration/system are you running and have you had any problems with backfiring?
    Cheers.
    '00 WH V6
    Dec 2005
    Not seen it done mate, theoretically possible and if done well it could do awesome things (considering the high RON of LPG), but it can't be done with a normal carby mixer, i suspect it might have to go dedicated LPG..
    Either way it wouldn't be a cheap solution. If you want something cheap to run the L67 isn't for you... GenIII responds very well to gas though, plenty of info on that and much much more power, likely more fuel efficient too.
    Driving a CURSED WH V6.
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    Contact (PM) this member who has had it done to his V6 S/C VT .....
    I like my roo well done
    VY Calais V8
    Jun 2005
    Mines got a SGI LPG install (dual fuel), mostly OMVL parts. No chance of backfiring with this system. Performace wise you'ld need a dyno to tell the diffrence in power and economy wise i got 400kms from the first tank city driving(took 55ltrs when i refiled out of 75ltrs useable), which is on par with the results i get with BP Ultimate.
    Running the SGI system you still need petrol as it always starts on petrol then flicks itself over to gas.
    scbh81's Avatar
    scbh81 is offline VRUUUM XU6 180 SC
    HSV XU6 VTII 99
    Jul 2005
    St Kilda Victoria
    I thought holdens doesn't recommend LPG on any of the supercharged engines. (It says on my manual) I didn't think it was a good option! And it is not cheap in the long run...
    There is no such thing as 'What if?'
    http://forums.justcommodores.com.au/...y-hsv-xu6.html
  1. VS V6 Supercharged Ute
    By centrifugal6 in forum VR - VS
    Last Post: 22-12-2009, 08:15 PM
  2. Supercharged VS V6 into a N/A VS V6
    By Spaced in forum V6 Development And Modification
    Last Post: 22-09-2006, 12:34 PM
  3. supercharged vl
    By macdee in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-09-2005, 05:16 PM
  4. VX Supercharged
    By spice weasel (BAM) in forum General
    Last Post: 30-08-2005, 05:14 PM
  5. Vs Supercharged $$$$
    By roger05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-07-2005, 02:30 PM
