hi just wondering if any1 knew if it is possiblt for your tail shaft to be out of balance and where or how u can fix it..
Yes it is possible for the tailshaft to be out of balance. A worn out universal joint can cause your tailshaft to vibrate. Also check the constant velocity joint and centre bearing for movement
thanx i will check them out tomorro.. cause something is vibrating down there it made my spedo sensor come loose last weknd..
