Results 1 to 13 of 13
Thread: do i need a camber kit
    VX S 5 speed
    Feb 2006
    Default do i need a camber kit
    hi guys
    i hope i am not repeating something previously discussed here
    i went to my local tyre shop today to get one of their free wheel rotation and "safety check" (i think they just check air pressures and make sure your tyres aren't bald). i went to get the rears put on the front so i can get a more even wear pattern out of them, but they wouldn't do it. they said the IRS that my car has made the rears wear out on the inside (and they're right!), and it's not worth rotating them - couple more months and i'll need new tyres on the back.
    my question is it worth buying a camber kit for the rear and how much do they cost? i have it on 18" wheels, but it is fitted with factory FE2 suspension, not any lower.
    i probably need to replace the suspension soon (but not the springs i don't think). will this fix the problem?
    thanks.
    VX S 5 speed
    Feb 2006
    oh ps - most of my driving is in a straight line. highways etc, not too many bendy curves needing massive camber on the wheels for high speed cornering.
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    Sounds like you will.
    My vt had fe2 with 17's and i need one, the vy i have now has half a kit in it with 18's.
    A kit with fitting will set you back around $500
    2010 Isuzu FXZ 1500 on 20's
    Oct 2006
    Bogan enclave
    Quote Originally Posted by bassmansimon View Post
    hi guys
    thanks.
    Short answer is yes. It will get rid of the scrubbing problem saving you money on tyres. I paid about $300 for the kit, so $500 fitted sounds about right.
    The problem seems to be under heavy acceleration when the rear end loads up, it ends up tilting the tyres inwards. Hence the scrubbing on the inside. Or when towing. First thing I did to my VY was fit this kit.
    Gothevu's Avatar
    Gothevu is offline Off the chain
    VU S2 Ute - 5 sp manual
    Jun 2006
    Townsville QLD
    with the vx you have to by two kits $100 each, its just replaying the rubber in your rear shocks coz the standard one don't have any give and when you give it a bit the ass end go down so the on give in the shocks
    The replacement kits is eazy to put it if you have tools and after you finish you have to get a wheel alinement it should cost all up round $250
    VX S 5 speed
    Feb 2006
    would it be a good idea to get this done when i'm getting the suspension replaced as the car has gone 140,000kms and is getting pretty soft?
    vxexec350's Avatar
    vxexec350 is offline <--6ltr VZ SS Ute
    VZ SS Thunder/VX Exec LS1/VN Berlina 5.0
    Oct 2003
    Adelaide Northern Suburbs
    Again...yes
    Pete
    Johnsy's Avatar
    Johnsy is offline ★★★★★
    HSV R8 LS3
    Oct 2005
    C/Town
    I thought the VZ's have that kit fitted as standard ? As mine are wearing on the inside rears as well and being directional tyres all i could do was flip the tyres on the rim and change them to the front that way..
    Gothevu's Avatar
    Jun 2006
    Townsville QLD
    The vy and vz have some adjustment standard but not much more then vt and vx
    Johnsy's Avatar
    HSV R8 LS3
    Oct 2005
    C/Town
    Quote Originally Posted by Gothevu View Post
    thanks...so i can adjust them out a bit more ?
    holden should have them straight as possible from the factory.
    VX S 5 speed
    Feb 2006
    yeh that price sounds about right.
    went to pedders today and got a quote on replacing:
    rear shocks $160
    rear cross member $180
    camber kit $135
    labour $255
    a few other bits and pieces to make the total up to $800.
    does this sound like a reasonable price?
    Gothevu's Avatar
    Jun 2006
    Townsville QLD
    SSZ-57L, they have some adjustment i'm not to sure on how you do it, have
    to go see holden or someone bout it a mate of mine got it done he said it help a lil bit but nothing to be happy bout,
    bassmansimon, that sounds like a good price, pedders have good stuff
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    Looks like I need one in my VS!!!!
  1. camber kit on vt
    By jezzaaa in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-07-2010, 06:45 PM
  2. camber kit
    By Noy in forum General
    Last Post: 23-01-2007, 06:03 PM
  3. !!!!!!camber Kit!!!!!!
    By nocky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-07-2006, 01:34 PM
  4. Camber kit
    By greatone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-05-2006, 08:14 PM
  5. VX camber kit
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-08-2005, 07:01 PM
