Results 1 to 14 of 14
Thread: overheating..
    MY10 SSV UTE
    Dec 2006
    Melb
    Default overheating..
    this morning when i left for work car started 2 overheat on the freeway, pulled over it went down took off again same thing then nothing.
    left work started again slowly, took my foot off (wasnt over reving it either) and it went down 2 normal and didnt move.
    any ideas? thanks
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    i'd say your thermostats playing up, and is your coolant level low cos that would shoot it up if you didnt have any.
    one more thing did your fan kick in?
    We got rep back, yaaay!
    JD
    VS Berlina
    Aug 2006
    Deep South, SA
    thermostat would need to be replaced.
    if it stuck closed like yours sounds like it is the it will cause it to overheat.
    the thermostat controls your car operating temprature.
    MY10 SSV UTE
    Dec 2006
    Melb
    come 2 think of it i just drove bak from the city not long ago and the temp was rising at a red light, drove off and it was fine mayb the fans arnt kikin in.
    MY10 SSV UTE
    Dec 2006
    Melb
    MY10 SSV UTE
    Dec 2006
    Melb
    myberlina's Avatar
    myberlina is offline BAD COP! NO DOUGHNUT!!!
    2006 VE Calais
    Aug 2005
    Melbourne, VICTORIA
    The second fan kicks in at 100 degrees me thinks.
    When was the last time you had your coolant replaced/flushed?
    MY10 SSV UTE
    Dec 2006
    Melb
    well i got 1 fan kicking in at 104 degrees, and the second doesnt do anything.
    cranked the aircon 2 full when i turn it off second fan spins acouple times then stoped.
    coolent woulda been changed about 13 thausand k's ago.
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by lumina01 View Post
    The fan/fans coming on at 104 deg is perfectly normal, and it will go off when the coolant goes under 99 deg from memory. Sounds like a dodgy thermostat as others have mentioned, but also check that your water pump is working properly.
    MY10 SSV UTE
    Dec 2006
    Melb
    Default .....
    wondering if theres a coolent over flow that makes it leak out from under the car if u've put 2 much in or have i got a leak?
    JD
    VS Berlina
    Aug 2006
    Deep South, SA
    yes the vx's do have a overflow tank and if its just leaked then it should be evident. ( its on the left side of the engine bay )
    if you cant see any leaks in the engine bay you may be up for a new radiator.
    MY10 SSV UTE
    Dec 2006
    Melb
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    There are two triangles on the dipstick representing MAXIMUM and MINIMUM fluid levels.
    When the engine is cold it should be at the Minimum mark and when engine is hot it should be a the Maximum mark.
    I like my roo well done
    VS Equipe
    Oct 2010
    NSW
    check if your bottom hose sucks in when you rev it, that may be blocking the water flow
  1. gen 3 overheating???? help!!!!
    By Xfordman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2011, 10:18 AM
  2. Vn Overheating
    By SV3600 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-10-2009, 03:49 PM
  3. overheating
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2006, 08:11 PM
  4. STILL overheating
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2006, 04:16 PM
  5. Is It Overheating Or What?
    By midnight.outlaw in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-02-2004, 07:49 PM
