+ Reply to Thread
Results 1 to 20 of 20
Thread: In "D", no power, as if in Neutral?
    Christina's Avatar
    Christina is offline Banned Christina Hitchhiker
    Almost genuine VT "S" + VZ "SS" Red Ute + Vk V8
    Jul 2006
    Default In "D", no power, as if in Neutral?
    Had some trouble with my VT last week.
    I was at the lights, i go to accelerate, no power. It wouldn't go, as if in neutral, i see that i am not in neutral.... a few seconds later with heavy pedal pushing, and then took off very sluggishly as if in a 4 cylinder .
    ... (got pulled over by the cops because they were behind me ), happens again when I tried to drive away, turn off engine, same problem on start up.
    Then worked fine later on. No idea, haven't driven my car.. until tomorrow when I get home, before I left it, it was fine.
    Any Ideas as to what that might have been? I haven't checked my transmission fluid... so is there a possibility of that? I was also on a bit less than a quarter fuel. Car drove fine the next day with low fuel... hmmm??
    Bad, bad, once off luck perhaps?
    Thanks for any help.
    NOT.BT1's Avatar
    NOT.BT1 is offline Bogan pride NOT.BT1 Berlina
    VN exec project vh in the shed
    Nov 2006
    geelong victoria
    chack your trans fluid theres a 90%chance its low
    Quote Originally Posted by neet_wagon View Post
    Instant Failure!
    What exactly IS a VD commodore? Is this some super hektic cop-special I've been missing out on?
    Quote Originally Posted by ari666 View Post
    basically OP is saying he has VD in his crapbox???
    didnt know you could get herpes of the anus, but hey! who am i to judge. have fun with your herpes OP!
    Christina's Avatar
    Jul 2006
    cheers Brendan, I will defenetly check it tomorrow.
    Craig has said this to me a few times, but wanted to just ask around.
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Christina's Avatar
    Jul 2006
    Quote Originally Posted by RVN 355 View Post
    ECU Playing up,get a flash test.
    oh?? how much would an ECU test from Holden be about?
    91 VN SS 355
    Feb 2005
    WEST SUBS
    not sure Any Mechanic these days should be able to.
    Mine does have the tool, Vt's are 10 years old,most mechanics should have the Gm flash tools these days any way.
    Cheers.
    * RVN 355 *
    Christina's Avatar
    Jul 2006
    Cheers RVN, i am going to go to my Mechanic if it happens again and check it out, he's a bit suss, but he'll do
    daron's Avatar
    daron is offline wizfiz daron Berlina
    VE SSV
    Mar 2006
    adelaide
    Christina's Avatar
    Jul 2006
    Quote Originally Posted by daron. View Post
    feul filter change it whatch it fly
    gah, didn't think of that, i guess the fuel might have been dirty when it was low.. plus old filter? grrr went crazy.. maybe!
    daron's Avatar
    VE SSV
    Mar 2006
    adelaide
    i was told to change them every 6 months i went nay no way since i did mine omg huge diference
    minux's Avatar
    minux is offline Infidel Bear minux W427 minux W427 minux W427 minux W427 minux W427 minux W427 minux W427 minux W427
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    if the car isnt moving under revs it is not a fuel problem, it sounds like you need a transmission service, if it were a fuel problem it would off chugged away under minimal throttle.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    02 VY SS
    Nov 2006
    Quote Originally Posted by minux View Post
    I agree...if you havent had you transmission serviced then get it looked at by a specialist transmission mechanic...even if your fluid is low it would be a good idea to get this done
    2 VL N/a's , 1x VL Turbo, 1x R33 Gtst
    Jan 2007
    Wodonga Vic
    i reckon it is the selectors on the gearbox has moved get your mechanic to have a look at that mate because if the gearbox had no oil it would be seized the selectors are a electronic cable hooked up to the side of the gearbox enabing you to tell your gearbox to change gear and also enables you to read your Gears on the tacho thats if you have a model that will let you see it
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep wrx884 Caprice
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Quote Originally Posted by VL HoWiE View Post
    Has that got somthing 2 do with the hydrolics that ur talkin bout?
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  15. #15
    Christina's Avatar
    Jul 2006
  16. #16
    burnz's Avatar
    burnz is offline dah dut dut da dah burnz Caprice
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by Christina View Post
    has not happened since, is a mystery to me...
    to me it sound's like vapour lock
    was it a hot day?
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
  17. #17
    Christina's Avatar
    Jul 2006
    "change 2nd to third.." "seems too slow changing"
    "too slow going down gears, it seems"
    thats what ive also been told recently.
    will be getting a transmission service maybe this week...?
  18. #18
    02 VY SS
    Nov 2006
    Good idea....
  19. #19
    IMCRZY's Avatar
    IMCRZY is offline RESPECT! IMCRZY Berlina
    M6 Hazzard SV6
    Mar 2007
    Wollongong
    If the seal on the auto filter is no in correctly it will suck air in with the oil & cause the gears to slip like crazy...
    & in some cases i have seen the wrong filter put in & the filter has come loose & fallin into the pan & then the pick up has not had been able 2 pick up oil
    I WISH MY GRASS WAS EMO SO IT WOULD CUT ITSELF
  20. #20
    Christina's Avatar
    Jul 2006
    i just got my tranny serviced, drives like brand new!
+ Reply to Thread
  1. ""need help"" own a stocko 3800 vp and wanting to really give it some horsepower
    By boourns in forum V6 Development And Modification
    Last Post: 19-07-2008, 05:59 PM
  2. V6 More Power - without a supercharger ""HOW?"
    By daffyy30 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-01-2007, 11:18 PM
  3. The "gears" and "power" in an auto
    By nath_120 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2006, 07:59 PM
  4. Questions regarding VR wagon smokey engine and power steering "hiss".
    By jayseventwo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2005, 12:32 PM
  5. VT Acclaim "power light" on dash stays on
    By getz in forum Electrical Wiring / Questions
    Last Post: 20-12-2004, 01:27 PM
