Hey guys, i wanna change my interior light to a calais one, with the reading lamps, ive seen it done before, has anyone done or, or know how easy it is too do? i heard there is an extra wire to run?? any help comments would be appreciated
thanks in advance
usually the wire is already there.
"Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
- Theodor Seuss Geisel
lol NFI, i paid an auto elec $50 to do mine![]()
thanx guys, i might even do the back yet
i just took mine apart to have a look and the interior lights got a clip on the end that u just plug in to the roof, hopefuly the calais ones have got the same clip so you just have to plug it in and do the 2 screws in again.
i just got told from razel it should bolt straight up, so hopefully i get mine this week or next week & ill do it, take pics & let you all know
I replaced mine with the Calais version (with the reading lamps) a while ago.
Its an easy job, straight replacement using the same mounting screws and wiring connector.
has anyone got a pic of it installed?
I did mine about a year ago in my 00vx. Justed unsrewed the old light, unplug it and put the new one in. Clips and srews are the same, rear courtesy lights i had to put my own loom in across the inside of the roof lining.
Shit just never happens..... Asshole's cause it!!!
what about running the rear lights off the boot light?
You will need to wire these rear lights off the middle interior light, so that they function properly with the on/off light switches and door switches.
I like my roo well done
i put my interior light in, but it dont work properly, when i put one of the reading lights on, it makes the middle light come on too but really dull, & when i put both on at the same time, neither work , but the center light comes on full, also the map lights dont work when the door is open
I recently bought one on ebay and it is the same as you describe. I thought there was a problem with it. I checked the wiring diagram for the interior light of an executive and a calais and they appeared to be the same, but there must be some thing different. I have a newer car now which already has those interior lights, I'll pull it apart tomorrow and see what's different.
ive heard its supposed to be a straight swap, who did you buy it from on ebay?
I thought it was a straight swap too, especially since the plug is the same. I bought it off someone called mandyd6415.
hmmm, i got mine from southern spares, somethings not right
When you guys get it working properly, post it up.
Here is a pic of the plug on the interior light with the map lights factory fitted. Unfortunately I don't have my VT with the standard light anymore to compare it to.
mine has 4 wires, but different colours? could this be it?
posted by charg'd
:: hakhawk :: says:
im a geek by day
:: hakhawk :: says:
a mass/axe murderer by night
:: hakhawk :: says:
and a rabbit sometimesI'm only nice to one person per day. Today is not your day....
Tomorrow doesn't look good either.
God must love stupid people, He made so many.
any ideas people??
I have a vx exe and did a straight swap with the lights.... just unscrew, unplug, install new light.
