Results 1 to 12 of 12
Thread: Oil in Coolant Reserve
    2000 VX Commodore
    Jun 2005
    Default Oil in Coolant Reserve
    I appear to have a brown oily substance in my coolant reserve. I only notice it on the coolant dipstick as just a thin film. There is no sign of emulsified oil on either the coolant or engine oil dipsticks or in the engine oil cap. No loss of oil or coolant either. There is no sign of oil in the radiator and if I put the coolant dipstick back in after cleaning it there is no sign of any more brown crap. Coolant is new also.
    Anyone know what this problem might be?
    Cheers.
    clixanup is offline Has Left
    Jan 2004
    V8 or V6?
    Many coolants are oily in texture anyhow. Did you change it yourself or did a workshop do it? The brown substance may be from deposits in your engine or heater core if it they weren't flushed properly.
    What would I do? Drive it around for a few more weeks, but keep an eye on the dipstick and watch for excessive steam from the exhaust.
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    It may just be the cooling system pellets that Holden recommends you install in the lower radiator hose when replacing the coolant.
    The pellets turn the coolant slightly brown from the normal green colour.
    I like my roo well done
    MY10 SSV UTE
    Dec 2006
    Melb
    Default ...
    I got the same thing in mine, was freaking out coz my car was overheating then when i checked the dipstick tiny lumps of that brown shit.
    I'd say it was due for a good flushing, probly just old coolent.
    2000 VX Commodore
    Jun 2005
    It's a V6 and I changed the coolant about 6000km ago.
    The cooling system including heater core was flushed out really well and I didn't put the pellets in.
    Jan 2004
    Quote Originally Posted by TigerVX View Post
    Are you 100% sure of that? Did you remove the thermostat & heater tap before flushing?
    VS II V6 Berlina
    Nov 2005
    It is normal for the overflow bottle dipstick to show signs of sludge. When working at d/ship I never saw another person remove overflow bottle to clean out when doing coolant flush. Remove bottle yourself and clean/rinse out with hot water (easier to get rid of sludge with hot water) then refit and refil with coolnt. No need to bleed bottle as only recovery bottle.
    minux's Avatar
    minux is offline Infidel Bear
    Mini Putt 2 Champion!
    Feb 2005
    lol, check your transmission fluid and make sure it isnt bright pink
    Sounds like you have a ruptured oil cooling line for the transmission that runs through the lower tank of your radiator(another completely pathetic design by holden).
    I'd just keep an eye on it even if your coolant has changed color. If this has happened, your engine will need to be pulled down and you will need a new gearbox.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    2000 VX Commodore
    Jun 2005
    The auto trans was my first concern but there is no sign of water in the trans oil.
    System was washed thoroughly inluding heater core and thermostat was changed.
    Coolant reserve bottle was removed from vehichle and cleaned out too.
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    sounds normal too me. theres always some sort of brown **** on the stick in every vt/vx ive seen
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eagle Vale, Sydney
    2000 VX Commodore
    Jun 2005
    Cool thanks guys.
  1. Coolant stuck in reserve tank
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2006, 09:15 PM
  2. Reserve
    By yamaha in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2005, 06:12 PM
  3. why does my reserve tank always drop
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-09-2005, 09:03 AM
  4. VN Calais on Ebay $1750 No reserve
    By blacki in forum Parts And Other Items For Sale
    Last Post: 25-11-2004, 04:38 PM
  5. Replies: 19
    Last Post: 15-07-2004, 06:25 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
