+ Reply to Thread
Results 1 to 20 of 20
Thread: Brake Pads
    Vt 50th executive
    Feb 2007
    Default Brake Pads
    Hey my Vt seam to be sqeeking. Does anyone know about the time brake pads need to be replaced, or is it just the type of metal? my cars done around 118000 ks,
    cheers
    OLS108's Avatar
    OLS108 is offline MR Helpful OLS108 Berlina
    Stockish VX Berlina
    Mar 2005
    QLD
    2007 VE Clubsport
    Nov 2003
    South Perth, WA
    is it?....im not game enough to do that....only thing i wont touch is the brakes coz i dont wanna not stop....lol
    how easy is it? coz i would do it if its not too hard
    Check out my ride here...E Series Chubby
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is offline Exhaust Guru Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Brakes can be a bit daunting if you have never touched them. It's just a matter of common sense and taking your time. I'm sure there would be a how to on it here some where. Just remember to follow the correct bedding in procedure or they will still squeal (also explained on here).
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    JD
    JD is offline Donating Member JD Statesman
    VS Berlina
    Aug 2006
    Deep South, SA
    Quote Originally Posted by matt182 View Post
    cheers
    doesn't really matter how many k's your cars done in relation to brakes, it more relates to how a person drives a car.
    We got rep back, yaaay!
    Vt 50th executive
    Feb 2007
    yeh i know it depends on how the car is driven, but i was just hoping someone could give me a rough idea
    JD
    VS Berlina
    Aug 2006
    Deep South, SA
    knowledge_is_power's Avatar
    knowledge_is_power is offline Quest for Cognition knowledge_is_power Berlina
    VT SII V6 A4
    Oct 2004
    Nth Brisbane
    How long the pads will last also comes down to the type of friction material used in the pad, as well as the vehicle itself, load carrying, towing, and your driving style. Generally speaking squeal is caused by excessive dust. In some cases it is because the pads are worn out and you have metal on metal. The pads you have can last from 500km to 30 or 40,000 km. Best bet is to have a look.
    An interesting fact is that the pads in the VE commodore are designed to last 60,000 km for the average driver.
    minux's Avatar
    minux is offline Infidel Bear minux W427 minux W427 minux W427 minux W427 minux W427 minux W427 minux W427 minux W427
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    If you do not want to do it yourself, ABS usually charge about $100 to do it for you.
    I couldnt be assed changing all my rotors calipers discs and pads as well as lines, they did it for me for $200.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    2007 VE Clubsport
    Nov 2003
    South Perth, WA
    Quote Originally Posted by Not_An_Abba_Fan View Post
    sweet mate cheers for that hey....yeh i think i had a bad experience wid this old dato's brakes which had drums front and back....i properly rooted them hey could rememeber how the hell they went back together....didn't help that i was only 14 at the time and they were all asbestos...lol
    cheers
    ryan
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The trick to doing drum brakes the first time is to leave one side intact so you can go around and have a look.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins Jesterarts W427 Jesterarts W427 Jesterarts W427 Jesterarts W427
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Yeah, i had a biatch of a time doing the drum brakes on my old FJ40!!
    Bastard to get off n some lil spring shot out n nearly too my eye out!!! lol
    I definately like disc better...
    VT Berlina / HT Sedan (project)
    Nov 2005
    Take the wheel off the hub, have a look at the amount of 'meat' or friction material left on the inside pad of that wheel. If there's any less than about 3-4mm, it'd be definitely worth replacing them.
    If the pads are worn any more than this the wear indicator should be just about ready to start scraping on the rotor, this may be already happening, hence the squealing noise you hear.
    If you can try and measure the rotors' thickness on the wheels you check too, use a brake disc measuring caliper (different from normal verniers etc, to allow for the lip on rotors) and compare your result with that in a service manual or stamped into the brake disc it's self (not too hard to find). This should help you determine if they need replacing/machining.
    You don't necessarily need to bleed the brakes but it might help to have new, fresh fluid in there(it'll need topping up at the very least if the pads are fairly low).
    Otherwise take it to a mechanic, if you're in doubt it's better to be safe than sorry when it comes to brakes, for obvious reasons.
  15. #15
    VZ Berlina
    Aug 2004
    cheers
    I had the same problem.Many people when they change their pads either lose or forget to put back the steel shim between the piston on the caliper and the pads on the disc.If you have no shims installed you can buy an adhesive glue in a small bottle, pink in color from super cheap auto.You apply it to the back of your pads and this sticks to the caliper piston preventing the pad from contacting the disc when you release the brakes.good luck.
  16. #16
    minux's Avatar
    Feb 2005
    Quote Originally Posted by satos View Post
    Or they simply do not bed them in properly.
  17. #17
    VX11
    Mar 2007
    Hi ,I am a mechanic in a country town where we hardly do heavey braking due to the nature of traffic.I have seen commodores such as vt to vz with up to 120 000 km on original pads.
  18. #18
    VU manual
    Dec 2005
    yeah i used to work at a large holden dealership, and fairly regularly id see vy and vz with 60,000kms and pads will still be good to last till next service, so i dont know whats so special about VE pads lasting 60,000kms when normally driven commodores are doing it already.
    Id say on average though the pads are usually replaced at 60,000kms because they get a bit on the low side then. so if thats true, depending on your driving style yours might need replacing at 120,000 which is pretty much now.
    Just get a mirror and a torch and look at the meat left on the pads, much easier than taking the wheel off.
  19. #19
    VU Storm
    Jan 2006
    60,000? do you guys use your feet to stop or something. I'm on my third set of front pards in 40k
    How to be a good Australian Citizen: Drive a Camry, Become another number in the system, Dob in all other numbers for un-numberlike behavior (no matter how slight), Base all your opinions solely on the information provided by T.T. and A.C.A., Believe everything our gracious Government Tells you to.
  20. #20
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    When you don't brake until you're 10cm from where you want to stop it will wear your pads out. Either that or you're using $2.00 Crazy Clark pads.
+ Reply to Thread
  1. QFM Brake Pads
    By gslrallysport in forum GSL RallySport
    Last Post: 12-08-2011, 02:39 PM
  2. How many k's from brake pads?
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 07:47 PM
  3. Brake pads changes.
    By Krustyone in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-07-2006, 10:02 AM
  4. Brake Pads
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-10-2005, 07:53 AM
  5. Brake pads
    By nervesplit in forum General
    Last Post: 11-12-2004, 05:31 PM
