Results 1 to 10 of 10
Thread: can you modify a vx vy ss cold air to fit onto a vt v6
    carless for now
    Feb 2007
    perth,Western Australia
    Default can you modify a vx vy ss cold air to fit onto a vt v6
    can you modify a vx vy ss cold air to fit onto a vt v6.would it be better to get a v6 s pac instead?
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    i think it should be doable, you will just have to use the box lid you have atm...
    I dunno, sounds doable
    redcv6's Avatar
    redcv6 is offline supercharged intercooled
    vy ss ute, diesel landcruiser 100s, hq panel van
    Aug 2006
    Ringwood
    i tried to put a vx gen111 intake on my vt v6, but something was stopping it, could have been something off the radiator can't really remmember. but i didnt try to modify it, just tried to stick it straight on. hope it helps
    johnny
    VYII SV8 One tonner
    Apr 2004
    Central Coast, NSW
    From memory the gen 3 airbox has an oval hole for the CAI to connect to.
    If you cut a hole similar in the VT box it should fit with a few 90deg brackets to hold the pipe inside the airbox.
    As for the actual CAI, it should bolt straight inplace of the factory VT cowling or CAI you already have.
    I remember i bolted my stepdads factory rediator cowling off his VY SS onto my VT untill i got my SS ind CAI.
    (Another thought)
    Id have a good guess that a VX/VY 5.7L airbox will bolt straight into your VT.
    Having a look around on K&N filters site, the part number for both V6 3.8 and V8 5.7 is 33-2116 which means your V6 lid will fit on a 5.7 bottom.
    I just hope it clips up properly.
    Check out My SV8 One Tonner
    You can get a lot farther with a kind word and a gun than a kind word alone
    VT Berlina
    Jan 2007
    does the ss cai actually perform better or is it better to get rid of stock stuff?
    what about the fit cai, anybody have 1?
    VX II Supercharged S pack
    Dec 2006
    Quote Originally Posted by jabsy1 View Post
    there was a post about the FIT CAI intake here recently, and its just a few rubber coolant style pipes sticking out the bottom of the airbox. Much better to go SS inductions or Augner for the money. You can make a FIT style intake for yourself though for less than $30
    Visit my photography site www.lcimagery.com
    carless for now
    Feb 2007
    would a vy ss cai give better performance? or better go with an ss inductions kit
    VT Berlina
    Jan 2007
    yeah i'm skeptical about spending 400 ss inductions gear. i actually just knocked up a pvc piping cai and its fine. goes really well. might even get an aunger one too just to step it up a notch. half price off ss, doesnt seem to be that different....
    Sphinx's Avatar
    Sphinx is offline O.G.
    VX Calais II LS1
    Aug 2005
    Pakky
    I'm thinking of dropping the bottom half of the Monaro airbox into my WH V6 and fitting in that plastic shroud that fits behind the headlight. Might even go for the big Gen 3 plastic cover that sits over the radiator to box it all in. Hopefully the holes line up in the bottom of the airbox with the metal pegs otherwise I'll be doing some drilling.
    The Calais
    Sleeper Club
    VYII SV8 One tonner
    Apr 2004
    Central Coast, NSW
    Here's a home made one i made for my VT.
    Just a bit of plumbers pipe with a 90deg bend in it going into the bottom of the air box.
    Cost me around 40 cents in wear and tear on my boots to walk down to a building site
  1. How Do People Modify
    By tr3nt in forum The Pub
    Last Post: 27-07-2006, 08:07 AM
  2. modify my vs 1997
    By tobesvs in forum General Discussion
    Last Post: 20-07-2006, 08:01 PM
  3. Ive got $2000 to spend. Want to modify my engine. What to do?
    By HIROLLA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2006, 12:06 AM
  4. Ive got $2000 to spend. Want to modify my engine. What to do?
    By HIROLLA in forum V6 Development And Modification
    Last Post: 05-06-2006, 10:46 PM
  5. Modify 98 VT Berlina, Auto, 3.8L
    By dlucre in forum V6 Development And Modification
    Last Post: 12-08-2005, 07:33 PM
