hi everyone
first off does any one have one of these or know if they are any good
second if so does any one know how to wire it to vx ss
It should be +ve, -ve and the signal wire goes to the -ve side of the ignition coil.
you have to wire it to the signal ouput from your ecu. im pretty sure you cant wire it to the neg of the coil as LS1's are coil on plug. meaning they have eight coils and you will only be getting 1/8 of the signal
Which state are you in?
if you are in adelaide we can help you with the wiring.
If you want to pm me with email address i can send you the complete instructions and part numbers for the vx gts shift light with pics. you will need to get someone to set the shift points with tech 2 or if you have modified the comp you may need them to do it for you.
