YByN8
- Jul 30, 2005
- 24
- 1
- 0
- Age
- 50
- Commodore
Hello,
I’m after some info on VT II front wheel hub(s).
The car makes a wering noise only when it moving, the faster you go the faster and louder the wering noise gets…..
I jacked the front of the car up and spun the wheels with my hands and the driver’s side wheel made the same noise it makes when driving, I checked for play in the bearings and there’s no play, just noise when it’s spinning. I pulled the wheel off along with the brake calliper and pads and spun the rotor, and the noise is still there! This makes me think the wheel hub / bearing is on the way out and needs replacing.
The car also slows it self down quite quickly if you get off the throttle and let it coast on a flat road.
How do you get the hub off?
There are 3 10mm grub / hex bolts in behind at the back of the hub, do you just take them out and wolla or is there more? The car does not have ABS.
Also is there anything else to check concerning this noise?
Thanx.
Thanx.
