Changing my manual trans fluid this weekend, just wondering, there is three plugs towards the bottom of the trans, i take it the bottom 1 is the drain plug but which one is the filler plug, they sit at the same height. One is the same diameter as the drain plug, the other is bigger in diameter.
Cheers guy in advance
i would have thought it would be on the side of the box
check out my ride http://forums.justcommodores.com.au/...ad.php?t=49768
Just had a look at the Gregorys and the pic shows the drain plug is the one thats on the bottom of the gearbox facing the ground then on the right hand side of the gearbox bout 2 inches up from the bottom of the box is the filler plug
There is a plug that is up the very top but will have a plug off it thats the reverse switch
Hope this helps ya out![]()
Thanx boganV8, im gonna have a go later 2day, ill let u know how i go
Cheers mate
