1. Take the fuel pump relay out.
2. Start engine until the motor 'conks' out. This is recommended to stop fuel pouring out of fuel line.
3. Get under the rear of vehicle and if needed, jack up the diff a bit.
4. Support rear on chassis stands where the two rear jack points are.
5. Remove fuel filter hold bracket as well as fuel filter inlet and outlet clamps.
6. Do everything in reverse and make sure the fuel filter you install points properly with the fuel flow. It should be marked on the fuel filter the direction of flow.
Done. Turn over motor! Might take a few seconds until the fuel flows from the tank, through the new filter and reaches the engine.
Hope this helps. See attached for diagram. :thumbsup:
