Results 1 to 4 of 4
Thread: maybe the struts?
    2000 VT Executive S2
    Jan 2004
    Default maybe the struts?
    hi all, at work so i dont have time 2 check through all the threads but ie just got a clunk in my front end when i go over certain bumps, and is worse if im turning a corner and go over a bump. just had the strut link bushes replaced so it cant be them. any ideas?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If the nuts on the link pins are too loose they will still clunk. The fact that it is worse when cornering makes me think the link pins and bushes are still the problem. Was it doing this before you had them done or just since?
    Gothevu's Avatar
    Gothevu is offline Off the chain
    VU S2 Ute - 5 sp manual
    Jun 2006
    Townsville QLD
    Jan 2004
    it started doing it for a day just after i had it done then it stopped and started again the other days jacked it up this arvo and found that the whole bottom bush, nuts and washers had all fallen out, looks like ill be going 2 visit the mechanic tomorrow
  1. Do VT struts fit a VS?
    By martinarmstrong in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2006, 06:17 PM
  2. anyone used air struts before?
    By vrmica in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2006, 08:55 AM
  3. Gas struts
    By fatboy2869 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-01-2006, 12:41 PM
  4. Vr /vs Struts
    By RVN 355 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-11-2005, 11:54 AM
  5. VR/VS Struts into a VN
    By mechanic22 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2005, 09:29 PM
