Results 1 to 11 of 11
Thread: Changing the fascia
    VXII S-Pack commodore
    Dec 2006
    Default Changing the fascia
    Hi guys, just bought a new fascia off ebay today, and was wondering how easy it is to change it? It doesn't come with instructions, and never done this before. Any instructions would be great, thanks
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    You mean the one that goes round the radio A/C controls and the speedo/tacho
    I know there is a lthread on here bout it will have a look for ya or if someone finds it first
    Dec 2006
    Yeah, the one for the speedo / tacho. Had a quick look for another similar thread but couldn't find it. let me know if you do.... Cheers
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    start with the bit where the power window switches would be - it just lifts off - then where the cigarette lighter things are a few screws to undo around the speedo shroud theres a couple as well - mostly then pulls straight off
    ford
    May 2005
    in a ford
    did you get both pieces? from memory, there is 2 screws near the cigarette lighter & a couple under the steering wheel
    IMCRZY's Avatar
    IMCRZY is offline RESPECT!
    M6 Hazzard SV6
    Mar 2007
    Wollongong
    Are u talking about the fascia 2 change the dial colours???
    I WISH MY GRASS WAS EMO SO IT WOULD CUT ITSELF
    VX Executive S2
    Mar 2007
    I found this link when looking to change my dash lights over but it's got full instructions on how to dismantle the dash and has pics to guide you.
    Blue LED Dash Conversion
    Dec 2006
    Quote Originally Posted by IMCRZY View Post
    Yep, bought a blue fascia for the speedo / tacho, want to know what I'm doing before I start pulling everything apart!
    Dec 2006
    Ok, had a go at changing this on the weekend, and ran into a bit of trouble. I managed to get the dash off, and the plastic cover for the cluster off, but could not get the needles or face off the cluster. Does the whole cluster have to be removed in order to change the face? Also,when the needles are taken off the face, do they need to be calibrated when put back on? Any help would be great.......thanks
    N/A
    May 2006
    It would be easier if you were to remove the cluster out of the car as you have to dismantle the cluster to change the face over. There should be two screws in
    the top of the cluster, then unplug the connector at the back.
    Im not sure how to dismantle the cluster to get to the face as I havent done it myself yet, but for the needles someone suggested to me that a fork or something
    of the same sort, and pry the needles up from the base. Once you have them back on, use the 'hidden' mode (hold up + mode when you start the car) and keep
    hitting mode till you cycle through to a screen that lights everything up, makes a continuous buzzing noise, and makes the needles move up. The tacho should go
    up to 3k rpm,speedo to 100km/hr and both temp and fuel should be in the middle. This will be how you know the needles are back in the right place. You can even
    use the digital speedo in this area and take the car for a spin round the block and check the speedo accuracy.
    Dec 2006
    Thanks heaps for that..... will give it a go and see if I can do it! Cheers
  1. Vt dash fascia with lcd screen
    By VTPREDATOR in forum Parts And Other Items For Sale
    Last Post: 03-03-2007, 05:52 PM
  2. VT HSV dash fascia swap
    By stevegunn in forum Swap / Wanted to Buy / Trade
    Last Post: 08-10-2006, 12:51 PM
  3. make use of mivr fascia
    By hoppersvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2005, 09:16 PM
  4. changing fascia
    By chirpies in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2005, 11:27 PM
