Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: High flow cats and extractors
    gamevx's Avatar
    gamevx is offline LS1 Calais
    LS1 VZ Calais
    Mar 2006
    South East Melb
    Default High flow cats and extractors
    I am thinking of gettin some extractors fitted to my V6. i'm gettin a set of pacemakers. Now what i wont to know is it worth putting new high flow cats in? its going to cost me just as much for the cats as the extractors, and some ppl tell me it not worth puttin new ones on a 6 cos the stock ones are ok.
    whats everyones opinion on cats?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Hi flow cats are not necessary on a stock engine. The standard cats flow enough. If you turbo or supercharge it then it would be ok but leave your standard ones there.
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    i have to race cats and makes a diference but then im charged but yes if n/a i wouldnt bother with twin but would still go high flow single
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    The local Carline Mufflers guy told me that if I get extractors, is should get a high flow cat otherwise i shouldnt bother with the extractors.
    2003 VY Acclaim
    Jul 2005
    Margaret River
    Problem is that the V6's need some backpressure and though the stock ones are a bit restrictive its not worth going hi flow cats unless you plan to go turbo or supercharged later on then
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by bill_randomhero View Post
    The only reason you were told that is because they wanted to sell you a hi flow cat. The extractors will give you the benefit, a hi flow cat will take it away.
    2003 VY Acclaim
    Jul 2005
    Margaret River
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Yeah, what Not_An_Abba_Fan said...
    I got headers, stock cat and then a 2.5 Catback behind that...
    Cause really got a kick in the arse will all that...
    Sure the cats might give u an extra 3kw but u will not feel that on the road.
    UNless ur gonna charge, then cats are an idea
    gamevx's Avatar
    LS1 VZ Calais
    Mar 2006
    South East Melb
    hmm... well while i'm on the topic, what type of extractors has every one got?
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    seriously tho, wats the standard cats diff to high flow cats, to a stock ecotec??? i cant see how itd change performance, its just a cat....
    p.s. dont throw abuse, just askin a simple question. i still run standard cats, as they were still in good nik when i got my zorst.
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    Quote Originally Posted by gamevx View Post
    pacemakers seem to be the way to go, but a lot of the guys run hm headers.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by VTPREDATOR View Post
    Absolutely no difference on an ecotec. If it was a super 6 then it would make a slight difference.
    A hiflow cat has a different ceramic substrate, the holes in it a slightly larger and the inlet and outlets flow smoother. There are also steel internal cats which all flow better than a ceramic hiflow.
    Big hp engines should run hiflows, stock ones don't need them.
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
  15. #15
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I got a set of Genies sitting in the shed, just haven't gotten around to fitting them yet. Would have preferred Pacemaker but at the price (Carton of Woodstock) I got them, I'm not complaining.
  16. #16
    VX Executive S2
    Mar 2007
    ive been tossing up the idea of exhaust and headers recently too. I had pacemakers with stock cat and 2.5" redback system with front muffler box only on my VL, and it sounded awesome. I was gona spend th e$ and get the HM headers aswell, but for those of you that have gone the headers with exhaust also, did u really notice any difference in power or anything, i know the note is important, but a mate of mine used to have a car exactly the same as mine engine wise, and he put on his catback exhaust first, but when he got headers later he sed he got no difference in power or noise, what's the story? Cos if i can get no difference in power or note by having headers as well, i dont see the point in spending the money.
  17. #17
    kimmys~vs~calais~sII's Avatar
    kimmys~vs~calais~sII is offline T5 calais girl..
    vs calais sII 3.8
    Feb 2007
    Im looking to get headders for my vs also..is their alot of difference between the pacemakers and h&m's?
    How much do they differ pricewise??
    T5 calais
  18. #18
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Exhuast n headers give you a powerband from about 2500 up and some improvement takin off...
    I was happy when i got my HM headers goin through a stock cat n then into a 2.5 redback catback with only the middle muffler
  19. #19
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    HM's are a bit dearer because they are stainless steel. Bit of a difference in power on a dyno, but unless you plane to drag it, there are no real differences between brands. Quality of build is a factor though. Which ever brand you get, make sure they have at least 2 years warranty, most have 3 now with stainless being between 5 and 10.
  20. #20
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
  21. #21
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I don't have a receipt, but I know where the guy lives that I bought them off.
  22. #22
    gamevx's Avatar
    LS1 VZ Calais
    Mar 2006
    South East Melb
    well Thursday my cars goin in for my new headers, got pacemaker in tuned length. So i cant wait!
  23. #23
    rickshaw
    Jun 2006
    Thanks guys, I was going to get a high flow cat before reading this, so you have saved me $250 bucks, which can go toward somthing else
  24. #24
    VT_Boi's Avatar
    VT_Boi is offline VT Holden By Design
    VT Holden By Design
    Aug 2006
    Sunshine Coast
    I run standard headers, standard cat and then my 2.5 system with lukey muffler. My mate has a VT with Pacies on it, my car actually pulls better than his, so why waste my money on extractors when I can put that into suspension and brakes and play in the twisties.
    Then The Boys Light Up.
  25. #25
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Your mates car is screwed then...lol
  1. hi flow cats
    By stateo 304 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-05-2010, 12:03 PM
  2. High Flow Cat's
    By Ford_destroya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-02-2009, 06:25 PM
  3. High Flow Cat
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-12-2007, 07:32 AM
  4. Hi Flow Cats
    By holden007 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-11-2007, 08:29 AM
  5. WTB high flow cat
    By lilkel in forum Swap / Wanted to Buy / Trade
    Last Post: 06-06-2005, 09:41 PM
