Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VT - VX Holden Commodore (1997 - 2002)
VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 02-05-2007, 11:18 AM
glowworm's Avatar
Ride: vt exective
Trade Rating: (0)
glowworm Executive
Default Jump Start
Can a vt v6 be jump started yes or no please let me know as my battery is dead,,
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 02-05-2007, 11:37 AM
accentstencil's Avatar
Donating Member
Ride: WH II Caprice, 5.7
accentstencil Caprice
You can but you must be careful. Make sure that both vehicles' ignitions are off. Connect the positive of the good battery to the positive of the dead one. Connect the negitive lead to the good battery and connect the other end to a good grounding point of the car with the dead battery Do not connect it to the negative terminal ot the dead battery. Then start the car with the good battery and then start the one with the dead battery and leave them running for about 10 minutes. Turn both vehicles off and disconnect in reverse order. If you follow this procedure you shouldn't damage anything.
Hopefully your car will start again. If not, I would probably disconnect with the car running, but it's not recommended.
__________________
  #3
Old 02-05-2007, 11:53 AM
glowworm's Avatar
Ride: vt exective
Trade Rating: (0)
glowworm Executive
Default cool
Thanks for that my car still doesnt want to start ..
  #4
Old 02-05-2007, 12:38 PM
NVE_069's Avatar
Vx Calais 5.7
Ride: Vx Calais LS1
Trade Rating: (0)
NVE_069 Hitchhiker
my car had a dead batt as it wasnt started for over a month when it was off the rd gettn fixed. i jump started it but u have to leave the other car running for a bit to let it put power into the other one then give it a go took mine few goes b4 it got any life but i still need a new batt.
there is also spec lead u can buy so u can put them both on the batt without probs
__________________
Always In Construction Mode!!!!!
  #5
Old 02-05-2007, 01:07 PM
STEALTHY™'s Avatar
So Wet For You!
Ride: VP Calais International, VP Berlina LX Wagon
STEALTHY™ SenatorSTEALTHY™ SenatorSTEALTHY™ Senator
If the person jumping your car doesn't have time to wait, just take your car for a long drive (maybe a half hour or so)
__________________
2001 HSV VX Senator Signature - 1 of 23 Manuals
-402 Stroked LS2-
-V7 Blower-
-Polished Intercooler-
-MSD Ignition-
-DiFillipo Exhaust-
-Tan Coulsons-
-Genuine VE GTS 20s-
-Fully Adjustable Suspension-
-Rip Shift-
Quote:
Originally Posted by commsirac View Post
try and sound like I know what im talking about
Sums up all of your posts!
Quote:
Originally Posted by paraphrased from Philthy
Stabbing someone, the same as having a loud exhaust!
  #6
Old 02-05-2007, 01:51 PM
Not_An_Abba_Fan's Avatar
Ride: MY08 Outlander XLS
Trade Rating: (0)
Not_An_Abba_Fan GrangeNot_An_Abba_Fan GrangeNot_An_Abba_Fan Grange
If the battery is completely buggered, it won't jump start. Do you have ignition lights when the jumper leads are connected?
  #7
Old 02-05-2007, 07:05 PM
glowworm's Avatar
Ride: vt exective
Trade Rating: (0)
glowworm Executive
Default battery
Yes the battery is good as i posted last week my car will not start and took it to holden and they couldnt fix it so the battery has been having a hammering with this prob i jump started it ok now i am taking the car to an auto elec next tuesday so fingers crossed that he finds the prob..
  #8
Old 03-05-2007, 05:50 PM
vuv6's Avatar
supercheap team member
Ride: 02 VU 3.8L Manny
Trade Rating: (0)
vuv6 Berlina
mate curious....wat would be a suitable grounding point? sumwhere on the engine?
cheers
ryan
__________________
Check out my ride here... VUV6
If i was helpful please click on scales up the top and give me sum feedback!
  #9
Old 03-05-2007, 05:57 PM
Donating Member
Quote:
cheers
ryan
Yes, the engine is a good grounding point, I forgot to mention that. Somewhere like the exhaust manifild would be good.
__________________
  #10
Old 03-05-2007, 09:07 PM
vuv6's Avatar
Trade Rating: (0)
vuv6 Berlina
thanks for that....i will now no for future reference
cheers mate
ryan
__________________
  #11
Old 26-12-2007, 06:46 PM
n0tepad's Avatar
Ride: VX Calais V6 Supercharged
Trade Rating: (0)
n0tepad Executive
glowworm: what was the problem with it?
  #12
Old 27-12-2007, 04:19 PM
Ride: 1997 vt v6 wagon
Trade Rating: (0)
pablo Executive
Just for safety's sake, I would like to point out that the reason for making the final connection, not on the negative battery post, but on a solid part of the engine block/manifold etc.away from the flat battery, is to ensure that any spark that may occure, no matter how small, will not ignite any hydrogen fumes from the flat battery.
My mate, one morning, found that he had left his parkers on over night, so he clipped his 'K-mart special' charger direct to the terminals and promptly blew the top off the battery. Acid over face, paint and his suit, not a pretty sight.
Pablo
  #13
Old 27-12-2007, 08:43 PM
Ride: vx
Trade Rating: (0)
commsirac Calais
Quote:
That was the reason I understood the procedure for as well. For a battery in open spaces with the bonnet up.........im prepared to risk the possibility of ignition.......given that any hydrogen produced by the battery in discharging or charging(the latter more prevalent) will be doing a lap of the stratosphere in no time. There is a slight advantage in using the engine block of the "jumped" car in that there is ~1/2m less cable for the current to travel through and this may make the difference in having the necessary voltage to turn the car over through the already long jumper cables.
The draping jumper leads near/over reciprocating parts of the engine is a far more likely source of a problem IMO, especially if the engine(s) have mechanical fans.
If one insists on earthing to the engine block, the best spot is possible where the battery lead meets it.
Any potential of problems for sparks igniting hydrogen when releasing the cables can be avoided by removing the cables from the good battery first.
  #14
Old 28-12-2007, 10:31 AM
