Results 1 to 10 of 10
Thread: suspension
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    Default suspension
    After a $14 pedders safety check ive got a report stating that ive got about $900 worth of work needed
    the list atm is
    - front shocks have about 6 months worth of life left in them- very boarderline
    - rear shocks have had it and need replacing
    - passenger front linkpin is bent and needs replacing(due to broken bushes)
    - most of the bushes need replacing on the front, didnt mention anything about the rear ones
    - trampo irs correction kit (camber kit?)
    now he didnt say anything was wrong with the springs, BUT in the coming months im considering lowering the car 2"(ssl?) all round and getting some 19" rims. As for the lowering i know it would look totally better lowering+rims at the same time so i can get the perfect height with the rims ect. but i dont have a spare $1500 for rims atm. so if i settle for just getting the suspension right for the time being, how much alone would the parts cost(not including the bushes/camber kit, so shocks/springs?), and would that be all enough if i supply the main things needed for lowering the car? Also the shocks have to match the height the springs sit at because it can cause problems later correct?
    As for the current prices he has given me an inbetween sports and comfort shockers for the front ($372) and the rear shocks ($166) and the irs kit at ($300). totalling $930 all up, or $714 just to do the front.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    now that u know what needs to be done go somewhere else!! lol!
    front shocks should cost u like 200 max, rears about 130 and thats monroe gt gas shocks.
    You will need a camber kit post lowering but get a 4 point.
    Pedders are really expensive generally
    Good luck
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    How can they tell how long is left in a set of shocks? They are either buggered or they are not. Those prices they gave you would be the pair not each. I supply fronts over here for $95 each and rears $75 each. Springs are $125 for fronts and $147 for rears. $160 for a four way rear adjustment kit. $37 for a link pin kit, new pins and bushes. It is recommended to use shorter rear shocks to trap the springs, fronts don't matter. Just don't use Monroe Sensatrac because they have two stage valving and it doesn't work when the car is lowered.
    Visit my Facebook page
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Jul 2006
    ahh well i guess the next question is, where can i get the cheapest parts sold seperatly, whether it be over the counter ect. or a workshop who will either let me supply the majority of the parts, or give me a decent price for them to supply
    VZ AWD One Tonner
    Jul 2006
    Ok, for Sep/Oct (but I've started already), I'm doing 15% off my already stupid KYB pricing...
    If you do end up going lowered springs, then KYB shocks to suit would set ya back $115 each for the fronts, and $57 each for the rears... Every second person can supply King Springs at a reasonable price, but if you're after one I can grab one too...
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    VZ AWD One Tonner
    Jul 2006
    Double Post...
    DND
    DND is offline Banned
    Feb 2007
    How hard is it to install the camber kit ??
    Could it be done at home without any problems
    I have heared that there a bitch to install
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Can be done at home, and its a b*tch to do...
    Did one on my mates statesman and it was an angry afternoon...
    Main issue was getting the bushle things into their spots...
    myberlina's Avatar
    myberlina is offline BAD COP! NO DOUGHNUT!!!
    2006 VE Calais
    Aug 2005
    Melbourne, VICTORIA
    I just got all my bushes changed in the front changed at Pedders and it cost me $850 odd. They were so stuffed it had to be held overnight!!! HAHAHA. I am such a prick to my car.
    Not only the bushes were stuffed. There was some part in the front strut towers with bearings in it -- totally f'd. Also the wheel alignment was performed.
    I drove around with the screwed bushes for so long I forgot how good it felt to have a solid suspension with A+ alignment!
  1. FE2 suspension
    By chevy_big_block_bro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2011, 09:09 AM
  2. VS Suspension.. FE2
    By mrbeef in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2007, 02:05 PM
  3. VS suspension
    By VScom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2005, 11:16 AM
