Solution to sagging bonnet gas struts
frustrated
VT Station Wagon
G'day folks,
Over the years I have been seriously fed up with the bonnet closing on me when working on the car, the last straw was when the bonnet slammed shut and the retaining hook when straight through my digital multimeter. So ...
I thought I would share with you'all my simple solution to sagging bonnet gas struts: put a piece of PC pipe over the struts. If you cut the pipe to the right length, it nicely engages when you open the bonnet. And it is easy to release by pushing it appropriately after taking the strain off. The pipe can be readily installed by removing the gas strut at the top, and slipping the pipe over.
A picture, attached, is worth a thousand words.
Michael
DND
Banned
I Bend my ones and it works good :thumbsup:
When its fully open Push on the mid of the strut (not to hard)
See in my photo how much you need to bend it :w00t:
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Or you could just buy new ones....
I bent mine on my XF that I had.
br14nh
Back in the saddle....
SW Sydney
VX V6 wagon 5sp Manual
There is also a crowd called "Strut re-gas" that will recondition existing ones - worked a treat for the sagging struts in the tail gate of my old VP wagon - look 'em up on the web, if they don't serve your area, they may have contacts of a crowd that do...
frustrated
VT Station Wagon
Re-gassing is OK, but it is expensive. The last time I asked it was going to cost about $100 to do four struts. I don't know how much new struts cost.
RockyVX
VX Executive Wgn, VP Sedan, V6 Ride on Lawnmower
I bought a pair of gas struts for a VX bonnet a few years ago, as an esky lid holder for the boat :) From memory they were $25 the pair back then. :)
I would guess that you could probally pick up a pair for fairly cheap nowadays.
wrx884
WA's ASR Rep
39
VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
yer y not lash out $30 4 a new set no messin bout straight swap ;) i had 2 do the same after 9 years my bonnet struts decided 2 pack it in so if the new 1ns even last half that im happy as larry
frustrated
VT Station Wagon
Well, if new struts are only between $12.50 and $15 each, then it is definitely worth replacing them. I wonder why regassing is so expensive?
Stupa
37
VU Storm
cozthe struts are so damn expensive
RockyVX
depends on where you buy them from. I have seen them selling for $80 a pair, which is rather ****e.
And as for the cost, thats like saying "why does holden charge me $50 to install a rubber grommet?". They want your cash. :)
