Results 1 to 11 of 11
Thread: clutch fluid on pedal
    VT series 2 S M5
    Nov 2006
    Default clutch fluid on pedal
    there was a thread b4 the site went down but i cant remember what i need to fix the problem, can any1 help????
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yep, that was it. The new master cylinder comes with the rubber grommet that you see on the inside of the firewall.
    Visit my Facebook page
    VX lumina
    Apr 2007
    Callington SA
    You may not have to replace the master cylinder, pull the master cylinder off, dismantle it & inspect the bore if it is not too badly worn (a little groove where the cup sits) you can hone it out with some fine wet & dry and put in a kit, replace master cylinder & bleed.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    For the price of a new one though, I would replace it.
    VT series 2 S M5
    Nov 2006
    can anyone tell me how to bleed the master cylinder? is it pretty much the same as the brakes, undo the nipple, hose over nipple then into container of clutch fluid?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yep. Fill M/cyl reservoir up, open bleeder, push pedal to floor, close bleeder. Repeat until all air is gone. Keep reservoir topped up.
    A Pushie
    Mar 2006
    Cronulla, NSW
    Quote Originally Posted by todro View Post
    Same as bleeding a slave cylinder.
    You need to open the bleeder on the slave cylinder, push the pedal to the floor, close bleeder, release pedal... then repeat until you see no more air bubbles in the bleed line.
    A new master cylinder will cost you $180 from holden.
    helay39 is offline VTV85L
    VT exec 5L Manual
    Apr 2004
    south cost nsw
    2007 VE Clubsport
    Nov 2003
    South Perth, WA
    Mar 2004
    Before you refit your new/reco master cylinder, "bench bleed it".
    Put the M/cyl in the vice and put fluid in the reservoir.
    Place a screw driver in where the clutch rod goes
    Put a finger over the hole where the pipe screws in.
    Push the screw driver in and fluid will be pushed out of the hole that your finger is trying to block, keep your finger firmly over the hole while you let the screw driver return to its outward position.
    Do it a few times, not letting air get sucked back into the hole that your finger is blocking. (This bleeds the air out of the master cylinder before you fit it).
    Keep your finger over the hole while you bolt the cylinder back on to the car, screw the pipe back into its hole. Then get a mate to sit in the car, loosen the pipe that you just tightened and tell your mate in the car to steadily push his foot to the floor and you will see brake fluid and air bubbles some out of the base of the nut where the pipe goes through it, as soon as your mate says "pedal to the floor" nip up the pipe nut, tell him to steadily let his foot off the pedal, do it a few times and it should get the air out of the system without having to get under the car. I have done it several times and it works well.
  1. Wtb:vs Clutch Pedal
    By janhdt in forum Swap / Wanted to Buy / Trade
    Last Post: 25-11-2007, 12:43 PM
  2. high clutch pedal
    By dogsfoot in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2007, 11:54 AM
  3. squeaky clutch pedal
    By dandandaniel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2006, 09:26 AM
  4. Clutch Pedal High
    By VNicko in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-02-2006, 02:57 PM
  5. VR Clutch Pedal Vibrations
    By MuNtEd in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2004, 08:35 PM
