+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 39
Thread: Jolting at 80 -100kms
    VT Berlina
    Sep 2007
    Red face Jolting at 80 -100kms
    I have just purchased a VT Berlina 98. When cruising along at about 80 - 100kms/hr and I accelerate slightly the gearbox cant decide if it wants to change down or not. It jolts as if it is going to change but doen't. It is only if you put your foot down further that it will change. The problem seems the worst when on cruise control and it goes up a bit of an incline. Any ideas what may be causing this?
    Cheers Scott
    P.S. the transmission fluid seems to be ok but will change it anyway
    Jun 2005
    its probably got something to do with the torque converter locking and unlocking
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is offline Exhaust Guru Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Look at your leads, one that is on its way out will make the whole car jump when under load.
    http://www.facebook.com/?ref=home#!/...21292461287296
    ivaninoz's Avatar
    ivaninoz is offline Ivaninoz ivaninoz Executive
    VS SerIII Statesman
    Nov 2006
    Millmerran, on the Downs, Darling
    Lightbulb Like driving over Tram Tracks, Clunk, KLUNK!!
    How many Kilometers has the car?
    Have you had any work done on the G/Box?
    Have a read just past Half way down, interesting, if true.
    TransGo Stage 2 Shift Kitted Valvebody Turbo 700 4l60E - eBay VN, VP, VR, VS, Holden, Car Parts, Cars, Bikes Boats. (end time 10-Oct-07 20:27:46 AEST)
    Corrects/Reduces/Prevents - 3/4 clutch and 2nd band burn up
    - Slide bump 1st to 2nd shifts
    - Reverse to Drive delay bang
    - Neutral to Drive delay bang
    - Forward Clutch and Low/Reverse Clutch burn up
    - Long and soft aggravating shifts
    - Converter slip/shudder around 90kms
    - Overheating caused by slipping converter.
    Ivan in Oz,
    Over the Hill, SEQld
    MOTOGuzzi T4 and Cali III Dresser
    1985 735i Bemmer............
    1998 Statey......
    VT Berlina
    Sep 2007
    the car has done 120k not sure if any work has been done on the g/box but it only does it downshifting from 4th. All other changes seem ok for a commodore (rough for a toyota etc.) It is a bit intermittent and will only do it under load at about 1600 - 1900rpm with light accelerator. If I give it a bit of stick it will change down fine. The engine seems to be running nice and smooth so I think it is definitaley gearbox related.
    Thanks for the help
    Scott
    ivaninoz's Avatar
    VS SerIII Statesman
    Nov 2006
    Like NAAF said,
    check your Leads and maybe Coilpack.
    If one Sparkplug fails then the other on that Coilpack also fails.
    Yes, the symptoms are like it is coming from the Gearbox.
    Ivan in Oz,
    1998 Statey......
    burnz's Avatar
    burnz is offline dah dut dut da dah burnz Caprice
    2010 CRUZE Diesel
    Jun 2005
    springfield
    are you getting any codes?
    sound's like a fualty t.p.s.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    pumba's Avatar
    pumba is offline OMR346 pumba Executive
    VZ SSZ
    Jan 2006
    brisbane southside
    sounds like a typical t700...
    my VS does the same thing at abit over 80km/h. and i no plenty of others that do it aswell.
    VX II SC Calais
    Oct 2007
    Quote Originally Posted by Scott98 View Post
    Thanks for the help
    Scott
    Hi Scott
    I have exactly the same problem you describe and I've only done 46,000KM, have you resolved the problem yet?
    I have been led to believe that this may be a software issue.
    Thanks
    Viper
    *VOLATILE*'s Avatar
    *VOLATILE* is offline Monaro here i come *VOLATILE* Executive
    VT Acclaim S2
    Aug 2005
    Huntingdale, Perth
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Had exactly the same problem; replaced my leads (once i had removed the old ones, all the leads were covered in a grey dust; which indicates "arcing" between the leads). Problem solvered.
    http://www.iplcricketnews.com/ - #1 site for all things IPL!
    VX II SC Calais
    Oct 2007
    Quote Originally Posted by *VOLATILE* View Post
    If it was leads wouldn't it do it under hard acceleration as well or is that not the case ?
    Viper
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It probably is doing it, but may not be noticeable because the car is accelerating hard. If it is an occasional miss, it would be more noticeable under light acceleration.
    *VOLATILE*'s Avatar
    VT Acclaim S2
    Aug 2005
    Huntingdale, Perth
    Quote Originally Posted by viper101 View Post
    Viper
    Even from the first gear changes (1-2, 2-3) when I tried to put my foot to the floor, the car would jolt. Heavily. Enough to make me **** my pants twice over. So for about 10 days or so, I was driving like Miss Daisy; even on the freeway. So that is definitely the case
    DND
    DND is offline Banned DND Executive
    Feb 2007
    My one done the same thing a 80 -100kmh if you were setting on around 80 to 100 and slightly acceleration it felt like it wonted to change gear
    After months of trying to find it and taking it to the meks that couldn't find the problem..
    Anyway It was dirty injecters and a $10 bottle of injector cleaner fix it...(one bottle of injector cleaner to 1/4 tank or petrol)
    I was total pi$$ed off for the $480 bill I got from the meks that didn't fix it and only broke more stuff them they fixed
    (thats what happens when you live in retard central)
  15. #15
    VX II SC Calais
    Oct 2007
    OK it's definately not the leads I have inspected and tested all leads and coil packs both primary and secondary coils and all are well within specs.
    It only ever does it when in top gear and you keep gently accelerating, it's like it want's to kick back and has a few unsucessfull attempts before it does.
    We have had it on a scanner and it reported error code 0700 PCM communication error.
    I think the injector cleaner will be worth a go I have ony used it once before in the cars life although it only has 46K on the clock, mainly highway driving, it's virtually brand new still.
    Viper
  16. #16
    Jun 2005
    i still reckon its something to do with the torque convertor locking up. it will do that around this speed to minimize power loss and increase economy. you gotta put the accelerator down a bit before it unlocks again
  17. #17
    VX II SC Calais
    Oct 2007
    Quote Originally Posted by stocky View Post
    I think your on the right track here as it only happens at the speed where it's locked up, on the S/C models it's actually the transmission that tells the engine to reduce torque before shifting, and I don't think that's happening when it's locked up, as you say if you put your foot down no problem it shift's back nicely, but if it's gently increasing acceleration especially up an incline it happens.
  18. #18
    Jun 2005
    well in the first post, it sounds like the first jolt is the TCC unlocking, and then when he puts his foot down more, it kicks back into 3rd
  19. #19
    VX II SC Calais
    Oct 2007
    Error I'm getting is P0700 Transmission Control System Malfunction. Any ideas where to start?
  20. #20
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa Doctor Bob GTO Doctor Bob GTO
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    this code doesnt relate to your car VXV6, this is only applicable if there is a Transmission Control Module, try getting a more compatible scan tool connected to it.
    as for the trans issue there is a memcal released to change the "lack of power" percieved when accelerating with the tcc locked
    Rob
  21. #21
    VT Calais Super6
    Jun 2005
    It sounds very familiar to me, it could either be your torque converter dropping in or out or if the car has been tuned it could be too little fuel in lean cruise.
  22. #22
    VX II SC Calais
    Oct 2007
    Last service it had the transmission serviced using a non genuine filter and it has only done it since then it could be a co-incidence but I'm going to try a genuine filter kit today and see what happens.
  23. #23
    VX II SC Calais
    Oct 2007
    OK filter and oil changed to genuine and problem is still there. I'm going to have to do some road tests and log with a scanner to try and work out what's going on.
  24. #24
    VX II SC Calais
    Oct 2007
    Quote Originally Posted by Doctor Bob View Post
    Rob
    Hi Rob,
    Where do you get the updated memcal from and any idea how much.
    thanks
  25. #25
    Doctor Bob's Avatar
    May 2004
    Hi Rob,
    thanks
    you need to see what memcal is in it now, post the code & ill look it up
+ Reply to Thread
  1. Transmission jolting
    By Patrio7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2007, 08:46 AM
  2. How to find out my fuel usage per 100kms
    By Fitzy3VSVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2006, 02:25 PM
  3. 22L/100Kms?
    By HIROLLA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2006, 08:11 PM
  4. jolting when excellerating
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-02-2006, 08:03 PM
  5. ?? / 100kms
    By Notorious in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2006, 05:02 PM
