My aerial seems to like getting stuck about 2-3 inches above the closed position... It will either get stuck on the way up or on the way down but it gets stuck in this position nearly EVERY time! (Very frustrating).
I have soaked it in WD-40 thinking that maybe the lowest section was a bit sticky but it has had no effect.
Any ideas?
If not, how do you get to the motor that operates the aerial?
Cheers.
You have to remove the plastic lining in the wheel arch to get at it.
MY RIDE
thanks mate, I'll give it a go if it keeps up!
Cheers.
