Results 1 to 10 of 10
Thread: Broken Power Supply
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Default Broken Power Supply
    In my VT the power supply or cigarette lighter is broken, which poses a problem cos they are just so handy for my phone and GPS. Anyway, I have no idea what is wrong except that a while ago when an adapter was pulled out of the power supply the supply insert came out too, not all the way just a little bit to make it loose, it may be a broken wire but I'm unable so look behind it to find out, any help on how I can remove any inside panels or facias to get behind the power supply would be really great, thanks.
    Dan
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eagle Vale, Sydney
    You have to remove the consul cover. 2 screws either side of the socket you are referring to, then lift the rear of the surround ( where the power window switch is, or the coin tray if you don't have power windows). You will have to pull it up hard because it is clipped in. If you have the power window switch you may need to remove that first because it can prevent the consul from being lifted up enough. I know it's like that with mine. You can lever the switch out with care, use a rag to prevent damage while levering.
    Also check the fuse because it may have blown.
    MY RIDE
    I thought I was wrong once, but I was mistaken.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    1998 vt executive
    Feb 2006
    tasmania
    yeah i'd check the fuse first dude if it isn't it'll be a pain in the arse you'll have take it all out and re solder the wire on but i can't see the wire coming off though you would of had to rip it out pretty hard for that to happen
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Hey guys thanks for the help. regarding the fuse, which one do I check? is there a diagram some where in the car? thanks again.
    Dan
    Vs stato international 5lt
    Sep 2007
    Ballarat
    if you pull down the cover under the steering wheel,
    there is a diagram on the back of the cover, and the fusebox is on the dash.
    find the cig lighter one and you will be set.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    if its not the fuse id say the hex nut has either come off and its not grounding nemore or the ground wire has broken off. wen i 1st purchased my VT it was the same as urs all i had 2 do was tighten the hex nut behind the 12V supply and it worked.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Hey all, just giving you an update. Checked the fuse and what do you know! a blown fuse... so I changed it and now the power supply works fine! Thanks so much guys I would have pulled the whole facia off and the problem only would have been a fuse. Now i just gotta wait and see if blows again... thanks again.
    Kind regards,
    Dan
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Hey all, the fuse blew again the other day, the hex nut was loose again, could this have cause the fuse to blow it the nut was loose and came in contact with another metal surface? I just wanna make sure its not a more serious electrical problem. Thanks.
    Dan
    May 2006
    If the power wire to the socket touches any oyher metal part, it will blow the fuse again. This is to protect the wire from burning out.
  1. pc power supply advice?
    By pow3rslave in forum The Pub
    Last Post: 21-11-2007, 10:23 PM
  2. VN: power supply - cooling fans for head unit
    By savage1987 in forum Electrical Wiring / Questions
    Last Post: 07-10-2007, 08:33 AM
  3. power supply to amp with no fuse
    By Dr.304 in forum Car Audio
    Last Post: 26-04-2007, 02:18 PM
  4. Power Supply to amp in boot.
    By Dolly in forum Car Audio
    Last Post: 22-04-2007, 02:48 AM
  5. getting a supply? ?
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-04-2006, 04:56 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
