Results 1 to 9 of 9
Thread: VT swaybar links
    1998 Acclaim
    Aug 2007
    Default VT swaybar links
    I am having trouble replacing my Swaybar link pins. Do both sides have to be jacked up and level for the pins to go in the slot. I seem to remember if both sides are up it helps the cause. I am out by about 1 inch and there is not much room left to jack up. Any advice will help.
    Burnout_bro's Avatar
    Burnout_bro is offline Donating Member
    HYPER VX SS/ R33 GTST
    Dec 2006
    i found one side at a time was easier and too drop the swaybar down on eachside when changing the links and rubbers.
    1998 Acclaim
    Aug 2007
    Default Nearly there
    I have the pin in, but I can't do up the bottom nut because there is not enough thread to catch on to. Is this common.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    You need to have both sides of the car at the same height. Use car ramps if you have any.
    Vs stato international 5lt
    Sep 2007
    Ballarat
    i find the easiest way to do them, is;
    1. jack car up and stands underneath.
    2. take front wheels off.
    3. undo all nuts on both sides.
    4. push sway bar down.
    5. turn steering lock to lock one side will come out on one lock then other side on oposite lock
    6. install new ones with lock to lock.
    7. put all nuts on loosly and only 2 threads.
    8. tighten all nuts up.
    9. fit wheels and lower.
    remember when replacing them that the washers go on the right way around or it will chop the rubbers out quicker.
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    Sep 2007
    Ballarat
    the washers go with the cup side towards the nut so the the nut is in the cup of the washer.
    daron's Avatar
    VE SSV
    Mar 2006
    adelaide
    Sep 2007
    Ballarat
    yeah it can catch everyone out, and it doesnt take long before they are stuffed again.
  1. Swaybar?
    By Spaced in forum General
    Last Post: 16-10-2007, 05:15 PM
  2. can u drive ok without a swaybar.
    By Burnout_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-03-2007, 03:44 PM
  3. help installing swaybar link pins
    By Timzo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2006, 04:37 PM
  4. help... cant remove rear swaybar links
    By beefcream in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2006, 10:13 PM
  5. Front swaybar
    By Rocky1 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-11-2005, 11:34 PM
