Results 1 to 8 of 8
Thread: Speedo out by ALOT!!! since GB Chagne
    VT Commodore S2
    Dec 2005
    Wollongong
    Default Speedo out by ALOT!!! since GB Chagne
    ok, changed me gearbox
    i got a 99 VT with 5sp GETRAG, it broke, i got a new one, from a VX, unknown model sorry
    when it came, the VSS was missing so i installed the VSS from my box onto it
    now, i had it adjusted down with feelers gauges, and well speedo is way out, very weird reading, will not go above 40kmh
    and when ya doing like 80 it reads like 35ish or so
    now there is a Speed Sensor Toothed ring on the shaft in which the sensor reads, is it at all possible that this one could have more or less teeth on it, the one on me old box i count had 40 teeth on it, maybe the vx one is different esp if they ran different diff gears
    VT EXECUTIVE
    Feb 2005
    Hey bud is there a speedo cable that goes into the gearbox?? I'm just thinking of my old commodore, if so you just might need to change the gear knob not sure of the correct name of gear thats in the gearbox, if I remembered correctly they come in couple of different colours find out what colour your gear should be, then change it. I had the same problem along time ago found out I had a white gear for the speedo which should have been blue.
    cheers
    Vs stato international 5lt
    Sep 2007
    Ballarat
    yeah, you may need to get a different speed senosor due to the gears inside the box may have different teeth,
    best thing to do would go see holden and see what other sensors they have listed for them, vx maybe totally different.
    just as long as its not a vy box, as vy they might have changed cos of the different clusters and stuff.
    VT Commodore S2
    Dec 2005
    Wollongong
    Quote Originally Posted by selvag View Post
    cheers
    no there is no speedo cable
    VT Executive S2
    Nov 2005
    Bankstown, Sydney
    the only thing i can suggest, is changing the ratio gear. dunno if this will help as this varies from car to car.
    VX Calais V6 Supercharged
    Sep 2007
    VT Commodore S2
    Dec 2005
    Wollongong
    vs 5ltr ute
    Jan 2011
    indigo valley
    having problem with my vs i just done a v8 conversion to it im also using a get rag box. i took the sensor ring from my old box (v6) and installed it to new box now have nothing, moved sensor closer to ring semmed ok at low speeds but way off above about 40k moved sensor further away and lost speedo again the trip meter is working but not accurate either.
  1. Dumb mistakes cost alot.
    By Jasoniumh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-12-2007, 10:57 PM
  2. Blowing alot of condensation at time
    By jonathanvb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2007, 07:47 AM
  3. blowing alot of headlights
    By BANKS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-10-2007, 12:35 PM
  4. i want to do up me commo, but i dnt have alot of money. What can i do?
    By bundy bear in forum V6 Development And Modification
    Last Post: 11-06-2006, 12:33 AM
  5. Make a VN-P run ALOT cooler
    By VPower in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2004, 10:36 PM
