Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VT - VX Holden Commodore (1997 - 2002)
VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 05-11-2007, 07:13 PM
Ride: 98 VT With S Pack
Trade Rating: (0)
AwaKen Executive
Default Battery In Key Died?
Yesterday my car broke down at a mates place, all i done was switched it off for about 2minutes, ran inside, came back and it wouldnt start
It goes to tick over, then dies..then just won't even do anything.
I've had racq out and they said its most likely my key, and to get my car towed to holden and get them to reset the key etc
Just wondering if it could just be the battery inside the key that went? and if its at all possible to replace that battery? Or does that reset all the codes etc too then?
Richard
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 05-11-2007, 07:37 PM
accentstencil's Avatar
Donating Member
Ride: WH II Caprice, 5.7
accentstencil Caprice
You should be able to start the car even if the battery in the key is flat, I think.
__________________
  #3
Old 05-11-2007, 09:05 PM
JSD334
Ride: VT Berlina S1
Trade Rating: (0)
jessedevery Executive
happened to me too in a VR... was strange ended having to get mechanic to change the ignition cylinder
  #4
Old 06-11-2007, 08:21 PM
bigonexeon's Avatar
Ride: vt series2
bigonexeon Executive
yeah you should as the battery in the key is for the central locking not the actual ignition
  #5
Old 06-11-2007, 08:29 PM
Ride: vx
Trade Rating: (0)
commsirac Calais
I was under the impression that the electronics in the key also unlocked the immobilser via the metal contact on the end of the module making contact with the rings around the ignition lock and that the battery would need to be working. Didnt think it would be possible to start the car with just the key otherwise.....Im talking vx here, dont know about other models atm. However, it does seem strange that the battery would suddenly give up, without warning, ie reduced range on the central locking etc......or maybe it doesnt work that way.
  #6
Old 06-11-2007, 08:42 PM
only milk comes in 2litrs
Ride: vt exec on 20s
Trade Rating: (0)
vt_on_20s Executive
yeah the little metal semi circle rings around the barrel touch the metal ball on the key and let the car know its the key... i tested this by putting a peice of plastic between the metal ball on the key and the metal on the barrel and the starter motor doesnt kick... you need the get the batt fixed on the key
  #7
Old 07-11-2007, 12:14 PM
Ride: VX Lumina
luminex Executive
yea bro, my dad had the battery in his key go flat, they are supposed to be irreplaceable, but he cut the grove on the side with a knife and managed to get it open. Then all he did was replace the battery and glue it back up.
Good as new
__________________
REAL MEN SMOKE TIRES
  #8
Old 08-11-2007, 07:07 AM
Ride: N/A
Trade Rating: (0)
lockmac Executive
had the same problem with a vxii calais... was the key that was dead..got the battery replaced and she was sweet as pie
  #9
Old 09-11-2007, 06:21 PM
Ride: VX Calais 01 3.8lt Ecotec
Trade Rating: (0)
vxcalais_01 Executive
Wheres the best/cheapest place to get a new key cut for a VX ? Mister Minute or whatever i think charge $80.
  #10
Old 11-11-2007, 01:04 PM
TheForgotten's Avatar
not for human consumption
Ride: VR EXEC
Trade Rating: (0)
TheForgotten Calais
fat chance getting any cheaper than that really. holden charge $170 last i checked. unfortunately with mr minit you need a functioning key to copy the code from
__________________
Quote:
Originally Posted by joe_rolls_commo View Post
If you have trouble, flood the c.n.u.t with degreaser, chuck some gravel in, put the cap back on and shake it like an english baby-sitter with an un-wanted red-headed love-child. Tally-Ho!
  #11
Old 11-11-2007, 04:47 PM
Ride: N/A
Trade Rating: (0)
9C1pack Executive
Or the GMH plastic credit card thingy that came with the car from new.
It has the;
Radio code,
The key blade code, so the locksmith can cut a new key blade without even having your old key.
The security code so the locksmith can encode the key head.
  #12
Old 11-11-2007, 08:01 PM
Ride: vx
Trade Rating: (0)
commsirac Calais
I bought a new key and remote for my vx from a local locksmith $100 as I only had one and the buttons were worn through and thought a spare might be a good idea!. They plugged into the cars computer to get the code to incode the new key, but as probably stated ^, there are numbers where they can just "key" in the details for the new remote. They also cut a new key, however, I had problems with this not turning in the barrel properly easily, they claimed the barrel was worn, key to specs etc. They actually had a couple of retrys at making the keys and all had the same problem(you'd think a locksmith could look at the old key and duplicate the worn bits), they gave me all the attempts, so now I have two spares which can turn in the barrel given a few minutes of jiggling! Had them take the old key out of the old unit and stick that in the new remote, just have to undo two screws and it works fine.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
car felt like it just died...wtf? beefcream VN - VP Holden Commodore (1988 - 1993) 34 27-03-2006 08:28 PM
VT died!!! lilkel VT - VX Holden Commodore (1997 - 2002) 3 01-01-2006 12:02 PM
She died......... rattattack1313 Jokes/Humour 3 01-12-2005 08:09 PM
VN wagon.. just died... :( eagle970 VN - VP Holden Commodore (1988 - 1993) 3 10-05-2005 10:08 PM
air-con? died when not used? dust_master Airconditioning (all models) 4 19-01-2005 07:53 PM
Facebook Proxy | Cell Phones | Credit Reports | Ringtone | Personal Loans | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
