Results 1 to 9 of 9
Thread: changing rear brake pads
    vt commodore
    Nov 2007
    Default changing rear brake pads
    how do i change the rear brake pads on a 00 vt commodore with ABS
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Slightly undo the wheel nuts, jack it up, undo wheel nuts and remove wheel. Undo the bottom slide pin bolt on the caliper and then move the caliper upwards to reveal the pads. Pull pads out, put new ones in. Use a gee clamp to push the piston back into the caliper (keep an eye on the fluid level in the master cylinder when doing this as it may over flow). Put some loctite on the thread of the slide pin bolt and reassemble making sure that the springs on the pads are square on the caliper. Pump the brake pedal a couple of times to push the piston out again. No need to worry about the ABS because the sensors are nowhere near the rotors.
    In other words, it's exactly the same as doing the front pads.
    MY RIDE
    vx berlina
    Oct 2006
    Default changing rear brakes
    Quote Originally Posted by lizard199 View Post
    i personaly would not pushing the brake fluid back to the master cylinder, crap can stuff your abs module, do a search on this subject, its easy just to undo your bleed nipple a bit when pressing back the pistons
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Wouldn't hurt to re-grease the slide pins at the same time. From memory, I had to make a thin section spanner to hold the slide pin from turning when undoing and tightening them.
    Pablo
    OLS108's Avatar
    OLS108 is offline MR Helpful
    Stockish VX Berlina
    Mar 2005
    QLD
    I done a DIY on rear brakes for my VX on another forum..
    let me know if you or anyone else is interested and i will post it.
    Dave
    vt commodore
    Nov 2007
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    this reminds me... must buy a bottle of brake fluid before I start working on replacing the front hubs and all 4 rotors + pads....
    In my opinion it's better to bleed the brakes at every pad change. You may find that your brakes weren't as good as they used to be not just because of the worn pads but also an air bubble or two. I figure, while you're working down there you might as well do it. Oh, and it will cost you very little extra to buy the fluid.
    It's important never to reuse a bottle of brake fluid. Use it once and if there is anything left over once all the topping up is done on the day you changed the pads, then toss the bottle (responsibly of course). Opened bottles have their seal compromised and this can lead to condensation and water contaminating the brake fluid. Not only does it change the hydraulic properties of your brakes but it can also lead to corrosion and damage to your brake system. Don't risk it. Buy new fluid today! tehehe (all seriousness though, always use brand new fluid for the aforementioned reasons)
    Last edited by s_ikari2015; 26-11-2007 at 07:00 PM. Reason: Adding important information
    I haven't lost my mind, it's backed up on tape somewhere
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Brake fluid also breaks down over time. Heat from braking deteriorates it and it loses its ability to maintain pressure. It's a very good idea to flush the system at every pad change or about every 20k.
    How did your old man go at golf yesterday?
    Visit my Facebook page
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Is it possible to flush your brake system yourself or is it best left to the experts
  1. Rear brake pads. Anyone changed them?
    By maginoodle in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-10-2007, 07:53 PM
  2. Different brand brake pads front & rear
    By gogoboygareth in forum General
    Last Post: 27-03-2007, 12:08 AM
  3. How many k's from brake pads?
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 07:47 PM
  4. Changing Brake Pads
    By COINERS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-10-2006, 11:53 PM
  5. Changing brake pads
    By me_011 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-06-2006, 03:56 PM
