Hey all,
I find myself on here every now and again to find out about a problem my brother is having with his VX.
The car in question is a VX Series 2 S pac with the supercharged V6, stock as a rock.
The problem is a hessitation in acceleration, you put your foot right down and it doesn't react for a good second sometimes three, then when it finally does react and kicks down a gear the acceleration from there is nowhere near smooth. It jerks around... you can actually feel the car lurch forward with power then back off for a fraction of a second, lurch forward for a little longer then back off again, sometimes it lurches back and forth every second.
It drives fine when cruising and slowly accelerating but as soon as you hammer it it dies in the ass.
I just replaced the fuel filter, air filter, oil change and fuel injectors and no change in any way.
Checked the plugs and leads; all good. Reset the computer too during the injector change and that made no difference.
I have noticed it's been a lot worse over the past 2 days (Melbourne has been 30 degree's +) however 3 days ago it was cold and wet and the problem was still there but nowhere near as bad.
The car does do a lot of short trips, in fact the car does mostly short trips, lucky to see a freeway every 3 months.
He only runs it on 91 octane (I know! I have a WRX and I run it only on 98).
Need all the help I can get.
I don't use windscreen wipers, i just use the superior handling of the STI to dodge the rain drops.
lol im of no help but i love your sig
Chuck Norris destroyed the periodic table, because he only recognizes the element of surprise
Haha thanks![]()
My supercharged VX did the same thing once it warmed up. It's the leads. No use checking them just replace them with brand new GMH once, fixed the problem right up, the supercharged engines are very fussy when it comes to spark and delivery, the plugs and leads have to be perfect.
96 EF2 Futura I6 Auto SedanSuperlows Front/Rear with Monroe GT Sport's, EL XR Front, 16" Tickford Wheels with 225/50 Wanlis
, 5% Tint, Sony Headunit/ 6 1/2" 190w Speaker's, Fram Air Filter/XR6T Snorkle, Pacemaker 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD
15.37 @ 147 KPH
Leads are next then.
Like you said VT Berlina 07 it does happen often up hills.
I'll replace them and give an update
Thanks guys.
Changed the leads with GMH ones and it is perfect now, just as good as when it was first bought.
Thanks fellas, I really appreciate your help.
dang so its not the tps then
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
Told ya it was the leads. Glad it fixed it up.
Ohhhh sweet... i always thought it was that... same deal with my car but i am not s/c.... so how much does that cost and is a diy job... i know jack or crap about cars....
I think the leads are like $50 from holden and it's a pretty straight forward DIY job.
